Will this work w/ VDC???
Old Aug 16, 2006 | 07:53 AM
BawlZTT's Avatar
BawlZTT
Default Will this work w/ VDC???
I am going to be putting DR's on after work to head to the track. Am I going to be ok with these tire changes?
Current
(F)245-40-18
(R)275-40-18
New
(F)245-40-18
(R)275-35-18 (DR's)
I am not going to put them on if my VDC flips out on me because I am going to run these for a few weeks.
Old Aug 16, 2006 | 08:17 AM
BawlZTT's Avatar
BawlZTT
bump - according to a website its only a 4mm difference btween the front and rear diameter. Is that enough to trigger the VDC?
Old Aug 16, 2006 | 06:43 PM
MIKE DEGUZMAN's Avatar
MIKE DEGUZMAN
BUMP!!!
Anybody?? Someone has to know...
Also, how bout 245/40/18 with 285/35/18.
I've seen both setups on diff cars here on the forum, but I'm unsure if any of them were equipped with vdc/tcs
Did the math on both, and both are within 3%. But I'm trying to figure out how sensitive vdc/tcs really is.....
Old Aug 17, 2006 | 07:43 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Some have said it is possible to run all four the same size while others say it causes SLIP on long sweepers at speed.
Nowhere that I have seen has anyone reported being able to run smaller diameter backs compared to the fronts. 275/35R18 is -.14" smaller than 245/40R18.
285/35R18 should be .13" larger than 245/40R18 but it's tough to say if it will negatively affect your car.
Also, among different tires, even of the same brands, these measurements are more of a guess than definitive. For instance the tread of a stock 235/50R17 tires are wider than stock 245/45R18 tires. So with numbers as close as .13", running them may be the only way to tell if they will cause SLIP
Chris
Old Aug 17, 2006 | 08:21 AM
caucasiancoupe's Avatar
caucasiancoupe
I run the drag radials size 265 40 18 on my stock wheels when I hit the track. I have had not one issue.
Old Aug 25, 2006 | 05:25 PM
KPierson's Avatar
KPierson
What brand are your tires?
Old Aug 25, 2006 | 05:30 PM
Why no turn VDC OFF?
Old Aug 25, 2006 | 05:40 PM
masterj26's Avatar
masterj26
I am running 245/40 and 285/35 and haven't had a problem with VDC, Falken FK452
GY-Z
Apr 6, 2004 09:05 AM
boma
Dec 22, 2003 01:58 PM
MustGoFastR
Mar 11, 2003 06:04 PM
qirex
Dec 21, 2002 09:59 PM
