help with tire size question
Old Aug 16, 2006 | 10:22 AM
DrDrilZ's Avatar
DrDrilZ
Default help with tire size question
this is in regard to going up a size in rims/tires. if the overall diameter is larger than stock, will my speedometer and odometer read higher than actual or lower than actual?
thanks
Old Aug 16, 2006 | 02:42 PM
DavesZ#3's Avatar
DavesZ#3
Yup. The normal recommended size upgrades are pretty close to the OEM sizes so you can maintain the stagger and mileage/speed readings.
Old Aug 16, 2006 | 05:18 PM
1nate7's Avatar
1nate7
thanks
Speedo/odo will read lower than actual.
Old Aug 16, 2006 | 05:52 PM
DrDrilZ's Avatar
DrDrilZ
ok thanks. thats kinda what i thought. btw this is for an f-150 truck going from stock 255/70/17 to a 275/65/18. this wont upset anything else will it, such as ABS or 4wd or whatever???
Old Aug 17, 2006 | 03:31 AM
cRAYz4life's Avatar
cRAYz4life
diameter:
stock 30"
new 32"
speedo will read 58 when you are actually going 60
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
Paul.
Oct 16, 2015 07:34 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
