Will these tires fit?
Old Aug 30, 2006 | 08:21 PM
DaveE's Avatar
DaveE
Default Will these tires fit?
I'm getting Blizzaks from a friend and want to put them on my Z this winter (to hopefully get through a Michigan winter). They're 225/40/18's. Will these fit on stock rims (I'll have an '06 touring)...
Oh, and he says he's used them for a few winters (on an RX-8) but doesn't have that many miles on them. What's a good way to check and see if they're worn out? Does the standard "penny test" work with Blizzaks?
Thanks...
Old Aug 30, 2006 | 08:25 PM
Swiffer's Avatar
Swiffer
Thanks...
You shouldnt have any fitment problems. But if he has used them for several winters, I would really check them over to see how worn they are. You will see that the Blizzaks have a special tread compound that is only about 1/2 of the tread depth. If you only see 1 layer of tread (I believe that a snowflake pattern shows once its past the first tread), then its already worn. The first layer is the one that is very good regarding the winter traction. The remaining tread is a standard tire compound.
350z82
Oct 1, 2015 06:25 PM
