Fitment Of A 305 On A 10.5/22 Offset Lowered
Old Sep 2, 2006 | 09:55 AM
JETPILOT's Avatar
JETPILOT
Default Fitment Of A 305 On A 10.5/22 Offset Lowered
I am dropped about 1.25" in the rear, and 1" in the front. I am looking to get a set of 9.5" +22 front wheels w a 265/35 tire,and a 10.5" +22 rear wheels with a 305/30 in the back. Does anyone know from experience if these will fit. My fender lips are rolled. I'm not looking for magic tricks like 4 degrees negative camber to make them work. If they fit lowered with the camber in spec please let me know.
JET
Old Sep 2, 2006 | 10:37 AM
Pac Man's Avatar
Pac Man
Jetpilot, what are you typed in? Me, nothing yet, just complex with a CSEL ticket.
Ok, not exactly your setup but close. I am running Eibach Pro-kit springs with about a 1.2" drop in the rear, 10" wide with a +18 and 275/40 Falken's. No roll and no rub, but dang it's close.
Hope this helps!
Old Sep 2, 2006 | 11:42 AM
Zexy's Avatar
Zexy
Should fit in well. Give it a shot. I highly doubt there will be rubbign issues.
Old Sep 2, 2006 | 11:56 AM
Red Dragon's Avatar
Red Dragon
You need a 305/25/20
Old Sep 4, 2006 | 10:22 AM
Tantrum Z33's Avatar
Tantrum Z33
265/305 setup will not work with your setup if you don't pull your fenders 10mm+ out or if you keep the stock alignment specs. The 265 would work if you raised your car up a little or dial in a little more negative camber in the front. A 305 in the rear would most likely require around -3 camber and some widening of the fenders. Hope this helps.
Post up the results if you decide to do this. I'm happy with my 255/285/35 setup, but would love a 265/305 setup without sacrificing straight line performance or modifications to the fenders. I think the biggest tires on a lowered Z without having to modify the fenders is 265/35 295/30 ...
Old Sep 4, 2006 | 07:57 PM
drumma022's Avatar
drumma022
VRT runs 305's on the NISMO LM4's which is x9 in rear I believe.
Tire Manufacturer's state their recommendations based on the capacities of the individual tire ... however you can run much higher and much lower than what is stated.
JET -- StatusAuto has a few guys with 275/30/19 F and I have seen a few guys with the 305/30 R on the same 9.5, 10.5 +22, so you shouldn't have a problem.
Old Sep 5, 2006 | 02:51 PM
SinCity350Z's Avatar
SinCity350Z
Track Whore
315/30/18 on an 18" x 9.5" wheel. In the old Hoosiers, we ran a 305/30/18 though.
Old Sep 5, 2006 | 03:25 PM
JETPILOT's Avatar
JETPILOT
I checked the rim width chart for a Michelin 305/35/19 tire and the minimum recomended rim width for that size is 10.5". So no issues there. The minimum rim width for the 265 was a 9" wheel. No problems there either.
I think I will keep the wheels I have now.
Does anyone think I will have an issue with a 305/30/19 rear on a 10.5" with a +28 offset? Or a 265/30/19 front on a 9" rim with a +31 offset? Remember... I'm lowered considerably.
JET
Old Sep 5, 2006 | 07:20 PM
Tantrum Z33
305's on 9.5 and higher offset will fit, but he's talking about a 10.5 with a 22+ offset.
Old Sep 6, 2006 | 07:25 AM
InSaNeZ's Avatar
InSaNeZ
I think I am also gonna try running 265/305 when I wear out my current tires which are 255/295.
Old Sep 6, 2006 | 07:45 AM
drumma022's Avatar
drumma022
5 minute search provided me these picture links ... this was a 305/25 on a x10.5 +28 .... http://s45.photobucket.com/albums/f8...t=20#imgAnch29
this is a 275/30 on a x9.5 +22 for the front ...
http://i14.photobucket.com/albums/a3...zegoldte37.jpg
this is a 265/35 on a x9 +35 for front ...
this is a 305/30 on a x11 +30 (which is the same as a x10.5 +24) ...
Old Sep 6, 2006 | 07:49 AM
drumma022's Avatar
drumma022
I personally like the 265/275 setup for handling for cars with 300whp or less ... being the power JET has, the 275/295 should be nice given the appropriate offsets.
Old Sep 6, 2006 | 11:12 AM
JETPILOT's Avatar
JETPILOT
Thanks Drumma. I ordered a 275/30/19 front and a 305/30/19 rear. Looking at the pics you posted I should be good with those sizes.
JET
Old Sep 6, 2006 | 02:22 PM
chris'smax's Avatar
chris'smax
Hope this helps!
hey pac man,
can you please post or send me some pics of your wheel setup? I have the same whee/tire and suspension setup sitting in my room and i am nervous about how it will all look. I want to make sure it looks good before i install everything.
Old Sep 6, 2006 | 02:39 PM
JETPILOT's Avatar
JETPILOT
Sorry I didn't see this earlier....
I am typed in the 727, and the DC8-70 series. The mighty 8. I no longer fly the 8. I'm in the 727 now, and I am being moved into the Airbus A300. Oh how I love the 727. Great airplane.
JET
Old Sep 6, 2006 | 06:26 PM
redlinez's Avatar
redlinez
The 305 on 11 example above is mine. It's actually +28 rear and the outside of the rim will be the same as your 10.5 +22. I'm lowered similar to yours, with rolled fenders. Michellins are slightly wider than Pirellis on an 11 so at 10.5 I think your setup will be fine. I rub slightly on the inside on real steep angles. You shouldn't have that problem.
My front is 275/30 on 9.5 +30 no rubbing. Michellins being wider and your offset difference I would think it would be tight.
Good Luck, post pics when you're done.
Bob
Old Sep 7, 2006 | 09:29 AM
Soundeffects's Avatar
Soundeffects
I've posted my setup a couple time but I HAVE NO RUBBING AT all.
Eibach prokit 1" or so frnt and bck
265/30/19 on 19x9 with +26 offset, not even close to rubbing in anyway.
295/30/19 on 19x10 with +22 offset, just barely gets by fender after I rolled and pulled the **** out of them, camber is aligned. 305 with +22mm offset will be ****ty unless more camber is ran
Old Sep 7, 2006 | 09:37 AM
JETPILOT's Avatar
JETPILOT
I decided to keep my rims and will be running 275/30/19 on the front mounted on a 9" +26 offset and a 305/30/19 on a 10.5" +28 wheel. This should work fine from what everyone is telling me. Agreed?
JET
Old Sep 7, 2006 | 09:39 AM
redlinez's Avatar
redlinez
Check
