15mm H&R spacer question
Old Sep 4, 2006 | 08:15 PM
ZlleH's Avatar
ZlleH
Default 15mm H&R spacer question
Are the H&R 15mm spacer universal for both front and rear? Some guy I want to buy the spacers from says he has 2 pairs, and he is saying he only has rear studs only.
That is wierd because there shouldn't be a difference in studs for front and rear, correct?
Old Sep 4, 2006 | 08:26 PM
g35pm's Avatar
g35pm
Should fit the front as well.
Maybe he thinks it only fits the rears because of that "dummy bolt" on the fronts.
Old Sep 4, 2006 | 08:57 PM
1nate7's Avatar
1nate7
There isn't a difference, but you need the longer studs to run the spacers. I assume he means he only has the studs for one set of spacers, you would need to buy another set somewhere else.
issyz
Jul 2, 2017 03:04 PM
