>>>>>>>Volk Owners Only<<<<<<<<
Old Sep 10, 2009 | 10:05 PM
  #1941
solidsnake's Avatar
solidsnake
^mmmm nice
Old Sep 10, 2009 | 10:15 PM
  #1942
SnyzzleZ's Avatar
SnyzzleZ
very nice yancy
Old Sep 10, 2009 | 11:31 PM
  #1943
TheFarmer's Avatar
TheFarmer
Beautiful cars Yancy!
Old Sep 11, 2009 | 11:31 PM
  #1944
R350nate's Avatar
R350nate
Old Sep 12, 2009 | 08:28 PM
  #1945
SnyzzleZ's Avatar
SnyzzleZ
heres 2 more of the seibons on my ppw.
Old Sep 13, 2009 | 06:46 AM
  #1946
kasimmmmm's Avatar
kasimmmmm
Old Sep 13, 2009 | 07:54 AM
  #1947
SIR_pierre's Avatar
SIR_pierre
i need some help here.. i want that wide look. im getting TE37 in R 18/10.5 and F 18/9
what offset should i have??
Old Sep 13, 2009 | 08:28 AM
  #1948
Jacob350z's Avatar
Jacob350z
with those sizes anything below +0 in the rear will poke and anything below +8 will poke in the front.
so i would recommend 18x10.5 with lowest offset you can get then add a spacer and then in the front 18x9 with lowest offset you can get you might not need a spacer if you can get a good enough offset.
so just go with the lowest offset you can get in the sizes and then add spacers to your desired pokeage
Old Sep 13, 2009 | 08:45 AM
  #1949
SIR_pierre's Avatar
SIR_pierre
ok.. becuse i had +22 on my 19´s with R10.5 and F 9.5 .. and that was kinda ok.. a little wider would be nice.. so i thoght +18 or +12 in the front would be fine..
Old Sep 13, 2009 | 09:22 AM
  #1950
kasimmmmm's Avatar
kasimmmmm
i'm running +12 front and back and i'm rubbing like there's no tomorrow... with -3 degrees camber too!
Old Sep 13, 2009 | 09:23 AM
  #1951
SnyzzleZ's Avatar
SnyzzleZ
I would go with +12 all around, or +12 in front and +18 in the rear. To me there is NO REASON at all to get the lowest offset possible then put spacers on a 10.5 width wheel.
Post a pic of a car with what you would like yours to look like.
Old Sep 13, 2009 | 09:33 AM
  #1952
SIR_pierre's Avatar
SIR_pierre
i really relly dont want that since im getting CF fenders.
and i also have a -3 camber both front and rear.
im going to run with Toyo R 888 tires. 295 in the rear and in the front i want to be able to have 245-255 and 265
Old Sep 13, 2009 | 11:23 AM
  #1953
R350nate's Avatar
R350nate
19X9.5 front with 265's doesnt rub
19X10.5 rear with 285's rubs but with rolled fenders doesnt rub
if you're worried about rubbing you need to worry about tires... not wheels.
If you're looking for "pokeage" that has to do with offset and spacing.
P.S. mine are +22 all around.
Old Sep 13, 2009 | 11:44 AM
  #1954
Voboy's Avatar
Voboy
http://rimtuck.com/setup.php?id=376
http://www.ob-photo.com/2008/09/Oliv...er-tyler-klee/
Old Sep 13, 2009 | 11:46 AM
  #1955
SIR_pierre's Avatar
SIR_pierre
i have rolled my fenders in the rear so i can fit 295 street tires now. i guess ill have to settle with 285 when it comes to racing tires.
no its not the wheels i worry about getting damaged. its my CF fenders.
pokeage??
Old Sep 13, 2009 | 11:50 AM
  #1956
SIR_pierre's Avatar
SIR_pierre
looks nice. i just want it a liiitle wider. plus im having the 10mm wider fenders
Old Sep 13, 2009 | 11:55 AM
  #1957
Jacob350z's Avatar
Jacob350z
you have to understand that the width sizes are different on the 18s your getting.
if you had 9.5 fronts then yes +12 would not be bad those would be flush but not really poking out. and the rears would need a spacer.
Old Sep 13, 2009 | 11:57 AM
  #1958
Jacob350z's Avatar
Jacob350z
unless your have huge tires there is not reason to why you would be rubbing.
i have 10.5 all around with +13 front and -2 in the rear and i dont rub.
im max on stock camber in the rear and have a arms in the front at -2.0 on fronts.
Old Sep 13, 2009 | 12:04 PM
  #1959
Jacob350z's Avatar
Jacob350z
this is pics of mine with 19x10.5 all around with +13 front and -2 rear and i dont rub.
running on 255/35 all around.
Old Sep 13, 2009 | 12:06 PM
  #1960
sry110's Avatar
sry110
I have 10.5 +22 rears with 285/35/19 toyo's and they rubbed until I got my fenders rolled. Lowered on Hotchkis springs and within OEM camber limits. But I wouldn't say 285/35's are "huge".
