Flipping Tires???
Old Sep 24, 2006 | 11:16 PM
stilzx61's Avatar
stilzx61
Default Flipping Tires???
My rear tires have inner camber wear on the inside but plenty of tread on the outter portion. I was wondering if it was safe to essentially flip the tires so the part with tread will be on the inside...
Old Sep 24, 2006 | 11:28 PM
510dat's Avatar
510dat
yes, you can do that, but since they're directional tires you'll have to have it done by a tire shop; they'll switch the tires and rims, so you can face them the other direction.
You should also have an alignment done at the same time so you don't just keep wearing out your tires.
Old Sep 26, 2006 | 06:35 AM
voodoo's Avatar
voodoo
gotta make sure your tires do not have a specifc side for "outside" though. mine do.
DOH!!!
Old Sep 27, 2006 | 05:15 AM
It will be fine to swap the tires.
Old Sep 27, 2006 | 06:14 PM
elidoc's Avatar
elidoc
Default timing for rotation
Is there a specific time? after how many miles? or would you flip the tires when you start to see wearing away
Old Sep 27, 2006 | 06:36 PM
You just have to make a guess. I replaced my front tires at 24,000 miles because of feathering. The tires were safe, just loud as hell. So I swapped my new front tires at 15,000 miles to avoid any wear problems. Cost is about $40.
If your alignment is OK, there is little need to swap tires. Unfortunately the only way to spot alignment problems is uneven tire wear.
Old Sep 27, 2006 | 08:43 PM
stilzx61's Avatar
stilzx61
well just got some falken fk 452's....these tires are pretty quiet, so far so good!
Old Sep 27, 2006 | 09:31 PM
Ken@Performance's Avatar
Ken@Performance
Performance Nissan
The falkens will get abit louder as you put more miles on. I have I would say 5k with the FK452's and it is pretty loud, sounds like a truck is rolling with me. But the tires stick pretty well , so I aint complaining.
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
