What's the point of going 19' 9.5&10.5 against 8.5&9.5?
Looks. There are alot of threads that would argue any performance benefits.
Bigger wheel usually means additional unsprung weight and more rotational mass.
Originally Posted by AroundMyHorn
better launch though
Depends. Been a while since I went to Physics class, but more rotation weight means more power is needed to get the wheels moving. Granted it would have to be a significant weight difference.
But your right about wider wheel/tire equals more traction.
Originally Posted by Minda
Ok. Thanks guys!
I will not be going any wider than 245 front and 275 in the rear. I assume 8.5&9.5 are perfectly fit for that.
19x8.5 245/35/19
19x9.5 275/35/19
Originally Posted by Wired 24/7
yes you're right
19x8.5 245/35/19
19x9.5 275/35/19
19x8.5 245/35/19
19x9.5 275/35/19
huh, i went 19x9 and 19x10.5 with the same tire sizes mentioned above. Should i have gone with different tire sizes?
mostly for look. I got 18X9 and 18X10 for looks and go. The wheels are light to begin with so having an extra inch in the back isn't that harmful. I dont know why though, people put a 275 tire on a 10.5'' rim. Thats pretty crazy. My 275 looks pretty stretched. If i could get this same look w/ a 9 in the front and 9.5 in the rear i would've done that.
Just a simple answer necessary. Thanks.
JET
Looks and versatility.
I can get a pretty wide tire with a 10.5 wheel but still fit a 275 with no problem.
I figured....
"Fug it, I'm already going with a 19" wheel! Aggressive width to match!"
How about those SUV guys that stick 22" wheels on their trucks, then have like a 7" wide wheel. Ugh...why go that big if you're going to have little traction and contact patch for braking.
I figured....
