Help needed
Old Nov 13, 2006 | 05:36 AM
y0shi's Avatar
y0shi
Default Help needed
I just purchased some winter rim/tire package and i tried installing it this weekend but i ran into a small problem.. there and extra bolt on the front brake rotor that does not allow my aftermarket rims to be installed... i remember reading here that it was not needed, is this true?... if so, how did you remove the bolt?
Thanks
File Type: bmp
Old Nov 13, 2006 | 05:39 AM
SweetDreamZ's Avatar
SweetDreamZ
Thanks
search and you will be rewarded...
it's not needed...take it out and they'll go on...
Old Nov 13, 2006 | 06:14 AM
y0shi's Avatar
y0shi
i tried searching, but i can't find that thread...
Old Nov 13, 2006 | 06:54 AM
tkrienke's Avatar
tkrienke
Top 100 Questions.
https://my350z.com/forum/2003-2009-nissan-350z/197329-the-top-100-common-questions.html
Old Nov 13, 2006 | 07:32 AM
y0shi's Avatar
y0shi
Q. I can't get my new rims to fit on the front. There's a little bolt there! What can I do??
A. That little bolt is there so your tire guys don't put your stock rear rims on the front by mistake. To install aftermarket rims, just get a 10mm wrench & unbolt it. Problem fixed!
-Thanks!!
sherm
Apr 11, 2020 05:21 PM
