Enkei RPF1 18x10.5 ALL AROUND
Old Feb 15, 2012 | 09:59 PM
  #181
TucsonG35's Avatar
TucsonG35
is everyone using hubcentric rings with rpf's?
Old Feb 16, 2012 | 02:06 AM
  #182
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I use them.
Old Feb 16, 2012 | 07:10 AM
  #183
scotts300's Avatar
scotts300
Originally Posted by ronn1
What times are you turning there? I ran there many years ago with the Porsche Club before and after they re-designed the track for F1 motorcyles. As a reference, I recall turning 1:43 in my street 944 Turbo. I had it set up pretty good though. I'm sure you're a hell of a lot faster! Loved the track...cork screw is a gas!
Not really! That's very fast! My best is a low 1:42 - need power! I think it's a very high 1:30 car with a competent driver:
http://youtu.be/rLLYvzdWjsY
Old Feb 16, 2012 | 08:24 PM
  #184
ronn1's Avatar
ronn1
Down the Cork Screw in my 944T..many moons ago:
Car was my daily driver..but had suspension..wheels and tuned for more boost.
scan0006.jpg?t=1329456081
Old Feb 17, 2012 | 10:51 AM
  #185
scotts300's Avatar
scotts300
Nice! Definitely many moons ago - Marlboro advertisements! I drove my gabillion horsepower 300ZX twin turbo there first. It was not a fast-lap car (1:46), but it sure zipped into T2, approaching the #4 brake marker at ~135mph. Yikes!
Old Feb 18, 2012 | 08:30 PM
  #186
ronn1's Avatar
ronn1
I ran the track before it was reconfigured in the early 90's. Turn after the front straight had a huge pucker factor...like entering a closet at 100MPH at the end of the front straight.
Yes..I'm an ol' fart guys...actually ran Riverside
Old Feb 21, 2012 | 11:39 AM
  #187
scotts300's Avatar
scotts300
T2 still has a huge pucker factor - one goes barreling in at 110, 120, (150!)mph, and has to do a complete u-turn.
Old Sep 17, 2013 | 06:30 PM
  #188
APS350ztt_Mitch's Avatar
APS350ztt_Mitch
Originally Posted by lixam
did someone say rpf1's????
negative offsets..hahaahha
What sizes are on this car?
19x10+25's???
Old Nov 17, 2015 | 05:47 AM
  #189
Melo_z33's Avatar
Melo_z33
Anyone rocking 295/35, 18x10.5 +15 on all four corners, I'm thinking of 2 different setups and that's one of them.
Old Nov 17, 2015 | 06:38 AM
  #190
HRMoneyPit's Avatar
HRMoneyPit
I run 18x10.5 with a 285 And I can tell you no way I could fit them. Already rubbing fender and the inside arm
Old Nov 17, 2015 | 07:00 AM
  #191
Melo_z33's Avatar
Melo_z33
Have pictures?
I have seen someone with 285/30/18 on all fours with 15mm spacer out back making it +0 rear +15 front, sits perfect in my book......not sure if it was in this site.
I'm trying to go with a wide, grippy, meaty stance, if I have rubbing issues in the inside il just add some spacers, body mods is the easy part since I will not be slamming it but I still might have to roll and do a slight pull.
Old Nov 17, 2015 | 08:14 AM
  #192
HRMoneyPit's Avatar
HRMoneyPit
The issue is the front. Rear you can run a 305. I have a 10 mill spacer in the back. I wanted a square set up so the spacers help the rear look good. As for the front no spacer will help. I'm touching the inside arm very lightly and the fender under compression
Old Nov 17, 2015 | 10:14 AM
  #193
terrasmak's Avatar
Trying to grasp this. I run the RPF1 up front or NT03 up front, and have no issue with inner clearance. My tire is not close to the arm and there is no way for it to touch the arm under compression or rebound. I'm also running 285/35-18 in the front, seems like a non issue.
On my NT03 I would remove the 10mm spacer and run a 5mm spacer to further reduce inner clearance and still be good
Old Nov 17, 2015 | 10:47 AM
  #194
HRMoneyPit's Avatar
HRMoneyPit
Yeah mine touches. I'don't take a picture if I had the car. Like I said it's very lightly. Leaves a light clean mark on my inner arm. And when my wheels are straight ni problems in my fenders. But when going up say a steep hill with the wheel turned my wheel gets stuck in the fenders and I need to power over it get the car to get up the hill. I have a +22 offset
I've seen people go more aggressive and have less problems idk why
Old Nov 17, 2015 | 06:04 PM
  #195
terrasmak's Avatar
Are you rubbing on the upper somehow, or are you talking about rubbing on the compression arm. Maybe your stops were cut for more steering angle
Old Nov 17, 2015 | 06:29 PM
  #196
HRMoneyPit's Avatar
HRMoneyPit
Not that I know of
The inner arm is so barely touching that I've had no problems and I can't even tell on the tire. It's just a small clean spot.
Old Nov 17, 2015 | 08:17 PM
  #197
jdepe's Avatar
jdepe
I was running nt03 18x10.5+30 square 275/35/18, 275/40/18 and added a 5mm spacer on the front and 15mm on the rear to make them +25/+15. Never had any issues rubbing. Sat nice and flush with the front and rear fenders.
Old Nov 17, 2015 | 09:46 PM
  #198
terrasmak's Avatar
Not that I know of
I would love to see a pic , something just seems off with your car.
Old Nov 18, 2015 | 04:28 AM
  #199
HRMoneyPit's Avatar
HRMoneyPit
When I get the car back if I remember I'll send you a PM
Old Dec 15, 2015 | 06:27 PM
  #200
Manny00's Avatar
Manny00
I'll be getting the BF Goodrich g-force T/A KDW tires. Wanna do a square setup of 285 40/18 and would like to know if I'll have any issues up front. Current setup now is 255 40/18 all round, fronts have no spacers and rears have a 8mm spacer.
