Is this gonna rub?
Old Nov 28, 2006 | 04:45 AM
Midnyte's Avatar
Midnyte
Default Is this gonna rub?
Here's the setup I'm thinking about buying but I'm not sure if I'll have to run a negative camber to make it fit without rubbing the fender wells, and I definately dont want it to stick out like an old school hotwheels car.
Front:
18" x 9", +26mm offset (6.11 backspacing)
275/35 ZR18
Rear
18" x 10.5" +27mm offset (6.9 backspacing)
295/35 ZR18
Thoughts...?
Old Nov 28, 2006 | 05:26 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Front:
275/35 ZR18
Rear
295/35 ZR18
Thoughts...?
I have 19s and I know that 285/35/19s will rub on the rear with my +18 offset. The best way to figure this out is go to the website of the tire that you are looking to put on your car and look at the rolling inflated diameter. Every tire is different by brand for the same size. You however have a very conservative offset so I'm pretty sure you will clear because the edge of the tire should tuck under. For some reason you do rub I would not run more negative camber than what you will already have with such a wide tire. I would roll/cut the fenders first because too much camber will cause uneven wear. I speak all of this in assumption that your car is dropped in some way.
Old Nov 28, 2006 | 06:53 AM
Midnyte's Avatar
Midnyte
I'm actually thinking about the same tires you have I just wasnt sure if the T1's would rub with such a wide rim at +26/+27. BTW - I'm at stock height. The streets around here aren't forgiving enough for more of a drop than stock.
Old Nov 28, 2006 | 10:27 AM
JDMFairladyZ33
If you are at stock height then there's no problems. I know for a fact that with a mild offset like a +22 on the rear you will not rub. One of the guys here in town at Jotech, local tuner shop, has 20x10.5 +22 rear Volk GT-Cs with 295/30/20s. His Z is also dropped about an inch. He has no issues with clearance even with uneven streets. I went with 285/30/19 on the rears because of my +18 offset. At stock height I have plenty of clearance. When I drop my car I will have issues with rubbing and I will have to roll the fenders. If you are planning to keep your car at stock height then 285/35/19s are actually the better fitment. You'll be fine with the Toyos.
Obadabot
Jun 18, 2023 11:31 PM
May 30, 2017 03:28 PM
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
