Has this ever happened or is it normal?
Old Dec 8, 2006 | 02:22 PM
mikeSSD's Avatar
mikeSSD
Default Has this ever happened or is it normal?
Sorry if this is something normal but do you guys ever have the SLIP light go on after a turn and you didn't even take it fast? This happens rarely but after I take light turns on the freeway, the SLIP light goes on and when I step on the gas it feels weird as if its not progressing forward normally. Can anybody tell me possibilities of why this may happen? I have a stock 2004.5 and barely got it from the dealer about 2-3 weeks ago. thanks
Old Dec 8, 2006 | 02:27 PM
What is the temperature?
VO...'s Avatar
VO...
Administrator
It happens...I vote normal.
Old Dec 8, 2006 | 02:31 PM
mikeSSD's Avatar
mikeSSD
im here in san diego, ca. temp. was about 65-70 degrees
Old Dec 8, 2006 | 02:33 PM
SLIP is sensitive to seams in the road, patches and uneven road surface. Traction suffers when the road surface is below 40 degrees.
Old Dec 8, 2006 | 02:34 PM
zownz's Avatar
zownz
hmm how do your tires look..how often does it happen? what are road condition? wet? dry?
Old Dec 8, 2006 | 02:45 PM
VO...'s Avatar
VO...
Administrator
good point. I noticed that today. We're hitting in the high 30's. SLIP kept activating in 1st and 2nd when it normally wouldn't. I just ended up turning it off for the remainder of my commute.
Old Dec 8, 2006 | 05:00 PM
HighwaySpeed's Avatar
HighwaySpeed
Talking
I vote for more beer!
Old Dec 8, 2006 | 07:24 PM
dbasal's Avatar
dbasal
That's the best post I've seen all day!
Old Dec 8, 2006 | 07:51 PM
MERK350Z's Avatar
MERK350Z
Default Hmm
i have a 2005 350ZR and once i was entering the highway and the light came on a few times any type of cracks or if the road becomes a little uneven the light then the slip will kick in. it has happend a few times with me so i think its normal to be honest.
Old Dec 8, 2006 | 09:13 PM
mikeSSD's Avatar
mikeSSD
ahh i see. thanks everybody
Old Dec 9, 2006 | 01:06 PM
With more time behind the wheel, you will be able to make judgments about the road surface. 40 degrees and a sunny day is better than the same temperature on a cloudy day. Evenings and high humidity can be perilous. The road is covered with condensation.
Old Dec 9, 2006 | 06:54 PM
Sponge's Avatar
Sponge
The SLIP light can also come on when you're rear tires are worn and the fronts are relatively OK. The front-to-rear tire diameter ratio that keeps VDC happy falls outside of tolerance and triggers the light.
Check the rubber on the rear, they might need replacing.
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
