What Spacers For 10.5 Hiros???
Originally Posted by 350Zteve
What offset are the wheels and what size tires are you going to run?
and the offset issssss... dont know... i thought hiros only come w 1 offset... how would i go about finding it?
i know nothing about wheels ...
First off, you're going to want to run 35 series tires or it will look funny. You need to know the offset before you can select a spacer. To be flush in the back with a 10.5" wheel you need an offset around 22-25mm. Keep in mind that 285's will rub with any offset lower than 27mm if the car is lowered. You will need to roll the fenders otherwise.
If the offset is closer to 30mm, then you can run a 295/35/19 tire, but it won't be quite as flush as a 22-25mm offset.
I am wondering the same thing, I want to get these rims also but dont want to get spacers, I just want to be flush and fill out the wheel wells so if I get 19x10.5 in the rear with a 25 offset will 275/35/19 fit flush?
Originally Posted by neonsinn2000
no1 knows?....... take your time people... i want the right answer.. =0)
Originally Posted by 1nate7
We can't tell you unless you give us the offset. Like 350Zteve said, run 35 series sidewall. I'd do 255/35 front, 285/35 rear.
u think a rim place would let me try on a bunch of spacers till i find the fit i like?....
how do i go about finding the offset on them?
Contact Axis directly
bcoffee20
Nov 19, 2015 06:39 PM
FromGtoZ
Sep 20, 2015 03:41 PM
