20 inch wheel Questions
Old Dec 23, 2006 | 05:49 PM
RayH's Avatar
RayH
Default 20 inch wheel Questions
Hey Guys,
My Girl has a 04 Roadster, I want to upgrade her wheels and tires for her. I recently went ahead and ordered 20" helo Tease 20x8. With Nitto 245x35 and with 275x35s on them.
I am looking at the receipt and unfortunately dont recognize the offset, but what I would like to know, would this config fit if the offset is correct? and what off set would be needed to make it work?
I appreciate the help, I want to amend the order if I
have to before the package is delivered to the store.
Thanks Ray
Old Dec 23, 2006 | 06:21 PM
HighwaySpeed's Avatar
HighwaySpeed
Lightbulb
Welcome!
I'd contact: tirerack.com They can answer all of your questions.
Old Dec 23, 2006 | 06:55 PM
djnc's Avatar
djnc
8" is awfully thin for 20's...you'll need a pretty low offset to make it flush with the fender...not sure how 275's will look on an 8" wide wheel either...probably should've gone with a staggered setup, but if you just have a much lower offset in the rear, it might work out ok
Old Dec 23, 2006 | 07:15 PM
bofa's Avatar
bofa
They shoud fit (depending on the offset) however I have heard that the 35 profile in the rear affects the speedometer reading slightly more than what you would have had with 30 profile tires.
You really should try to research before making purchases whenever possible, especially large purchases like wheels and tires.
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
