Is this the wrong offset ??
Old Dec 26, 2006 | 08:27 PM
emtae's Avatar
emtae
Default Is this the wrong offset ??
I have a set of wheels 18x8.5 and 18x9.5 both with a 20mm offset. I put just the wheels on the back to see how they looked and it appeared that the rim stuck out a fair bit from the wheel well. Are these the wrong offset ? (car is not lowered. Will they rub?) Tires will be 275/40 on back and 245/40 on front.
Old Dec 26, 2006 | 09:17 PM
Endless Shock's Avatar
Endless Shock
They are not wrong... I would say that are a little agressive... This basically means you have to camber them in... Depending on what brand tires you have I think you will be OK... Hope that helps...
Oh yeah Volk GTS are 17mm & 18mm offsets...
Old Dec 26, 2006 | 09:20 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
I have the +17/+18 GTS and the back barely sticks out a hair. I would think +20 would be closer in. But then again I've never seen a +20, only +22.
Old Dec 26, 2006 | 09:38 PM
Triple8Sol's Avatar
Triple8Sol
You should be just fine. People run lower offsets than that with a 10.5 in the back.
Old Dec 27, 2006 | 05:13 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
loweer your car...they will sit very nicely
rear fender rolling may be necessary, depends on the tire
Old Dec 27, 2006 | 07:15 AM
There is no right or wrong offset. Are you clearing the rotors and strut towers? Is the fender cutting the tire? If no than they are the right offset.
Obadabot
Jun 18, 2023 11:31 PM
