SSR GTH-2 Offset question
Old Jan 11, 2007 | 06:12 PM
SHIFT_KNOWLEDGE's Avatar
SHIFT_KNOWLEDGE
Default SSR GTH-2 Offset question
for the ssr gth-2 wheels
19" x 9" +31mm offset (front)
19" x 10.5 +43mm offset (rear)
Will this offset out the wheels to far in. ....in other words would you recommend spacers with these offset?
thanks for you opinions!
Old Jan 11, 2007 | 07:27 PM
JETPILOT's Avatar
JETPILOT
I have the same offsets and wheels sizes. If the car isn't lowered it does not need spacers. If it is lowered ,for aestetic reasons only, it will need 10-15mm spacers in the rear. The fronts could use 5mm spacers, but it is fine without them.
JET
Old Jan 11, 2007 | 10:44 PM
thawk408's Avatar
thawk408
JET
I have the exact same wheels and offsets just in 18s. I have a 5mm spacer in the front and a 15mm spacer in the rear and it looks perfect.
Old Jan 12, 2007 | 04:17 AM
SHIFT_KNOWLEDGE
thanks that helped!
Old Jan 12, 2007 | 05:53 AM
sluggoZ's Avatar
sluggoZ
IMHO. The 350Z was made for low offsets! Under +25.
For that kind of an investment...why fool around with spacers?
Old Jan 12, 2007 | 08:08 AM
MR_X's Avatar
MR_X
was looking at the same set up since tire rack has a good dela on them. I guess that's what you are looking at. I decided to not go with them because the offset where to high. but if you get them post some pics, all I find here are 18s and I think they are too small.
Old Jan 12, 2007 | 08:33 AM
thawk408's Avatar
thawk408
They are such a good deal right now that some spacers are not a problem for me. I got mine shipped to my door for 1175.
Old Jan 12, 2007 | 10:09 AM
SHIFT_KNOWLEDGE
by fooling around do you mean why take a risk with spacers?....i didnt know there were risk involved with using spacers!?!?!?!...
what are the risk?
Old Jan 12, 2007 | 10:10 AM
JETPILOT's Avatar
JETPILOT
There are no risks... Spacers are a non issue.
JET
Old Jan 12, 2007 | 10:19 AM
SHIFT_KNOWLEDGE
yeha this is the best deal i have seen. i dont think ive seen another 21 lb 19 inch rims that has a 10.5 rear go for this price.. if i get them im gonna powder coat them black and put them on around april.. im in jersey and it makes no sense putting them on in the winter. but when i put them on i will post pics!!!!!!!!
Old Feb 1, 2007 | 08:00 PM
blap0220's Avatar
blap0220
Just wondering, but what size tire would you put on these? Tire rack suggested 245F and 275R, but these seem to small.
Old Feb 1, 2007 | 08:24 PM
sry110's Avatar
sry110
Eh, lot's of people run 275's on 10.5" wide wheels. It will probably look a little 'stretched' (though not too much), but I would think that a 285 width tire is more appropriate. Lot's of people run 275's to *hopefully* avoid having to modify their rear fenders for clearance between the tire and fender. This of course also depends on what offset the wheel is. 285 tires on a 10.5" wide wheel with +25 or lower offset, and you're probably in rub city.
Old Feb 1, 2007 | 10:19 PM
thawk408's Avatar
thawk408
I run 275/35/18 up front with no rubbing issues at all. I currently have 275/40/18 on the rear and it looks stretched. I will be getting 295s or possibly 305s next and it wont be a problem to fit them. The rims have a really high offset. The rears are +43 and the fronts are I think a +31. I run a 5mm spacer up front and a 15mm in the rear and still have some room if i wanted to push them closer out to the fenders.
Old Feb 1, 2007 | 10:35 PM
JETPILOT's Avatar
JETPILOT
You should run a 275/30/19, and a 295/30/19. That's the size I am running.
JET
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
