Tire pressure
Old Jan 17, 2007 | 09:54 AM
J~KiLLa's Avatar
J~KiLLa
Exclamation Tire pressure
How does the Z measure tire pressure? If i put on aftermarket rims will the tire pressure monitor still work?
Old Jan 17, 2007 | 02:29 PM
DavesZ#3's Avatar
DavesZ#3
There are small sensors mounted in each wheel that transmit the pressure. The signal is picked up by an antenna mounted in the A-pillar and decoded by the computer and displayed in the multi-display.
They WILL fit some aftermarket wheels in the same mounting method as the stock wheels, it just depends. Mainly, it's one piece wheels. Multi-piece wheels and others require you to use the banding method described elsewhere on this forum.
If you get them mounted in your wheels, then yes they will still work. Just make sure you keep the sensors on the same corner (i.e. FL, FR, RL, RR).
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
