New tires and my VDC
Old Jan 23, 2007 | 04:04 PM
shanecrosby's Avatar
shanecrosby
Default New tires and my VDC
I've searched and found some answers and still have a few questions. I would also like to ask guys who aren't actually selling me the tires a question or two as well. I'm running a 19x8 rim with 245/40/19 all the way around. I want a fatter tire on the rear. My tire guy wants to sell me 245/40's front and 275/35's rear. -Nitto Neo Gen's
19x8" all 4 rims
Front 245/40 = 26.7" diameter
Rear 275/35 = 26.6" diameter
1. is the 275/35 ok for my rim?
2. will the diameter difference throw off my VDC?
I can't find a tire combo any closer in diameter according to tirerack
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
I was looking at the Pilot PS2's, but people have told me that unless I am tracking my car or something extreme, I shouldn't see a difference between the Neo Gen's and the PS2's. Any opinions? This is my first performance tire purchase and I don't want to make a mistake. Thanks everyone..
Old Jan 23, 2007 | 11:37 PM
shanecrosby
anyone?
Old Jan 24, 2007 | 12:10 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
When +1 sizing it is better to look up the specs from the manufactures website for the application chart. You want to have the new tires as close as possible to the OEM rolling diameter. I will use the 03-05 OEM 18" as the base numbers:
RE40
Fronts:
18 x 8 +30 offset with 225/45/18 Bridgestone RE40 25.9 rolling diameter.
Rears:
18 x 8 +30 offset with 245/45/18 Bridgestone RE40 26.6 rolling diameter.
(Verified on Bridgestone's application chart).
What you are looking for:
PS2:
Fronts:
8-9.5 inch wheel
245/35ZR19 Rolling Diameter 25.8 - Better fitment
245/40ZR19 Rolling Diameter 26.7 - Too tall
(Verified on Michelin's application chart).
http://www.michelinman.com/specs/pil..._ps2/2958.html
Rears:
9-11 inch wheel
275/35ZR19 Rolling Diameter 26.6 Good fit
Also, the guy who told you not to get the PS2s for performance reasons is full of crap. There's a whole long list of non performance reasons why the PS2s are better. Becareful when buying tires. Sometimes salesmen will push you towards another particular brand or model because they make a higher margin off the sales.
Old Jan 24, 2007 | 03:56 AM
DavesZ#3's Avatar
DavesZ#3
The standard sizing is 245/35 front, 275/35 rear. You don't really want the front and rear to have the same diameter, you definitely don't want the front to be taller than the rear, that will definitely throw VDC off.
Don't know if NEO GEN come in 285/35 for the rear but that would work better than the 275 as far as keeping some stagger.
Old Jan 24, 2007 | 05:14 AM
If the front tires are taller than the rear, will this confuse VDC?
https://my350z.com/forum/wheels-and-tires/203755-will-these-tires-work-with-my-vdc-enabled-car-read-here.html
Old Jan 24, 2007 | 09:40 AM
shanecrosby
ok, I've got the tires ordered. I am going to go forward with the Neo Gen's because of the price difference for the most part. It's a $400 difference. I have a buddy here at work with a Z. He's rolling on the Neo Gen's and says that he likes them. He did say the PS2's are a better performance tire, but with the way he drives, he can't afford replacing them. Here's what I've ordered.
Front
245/35ZR19 25.79 overall inflated diameter
Rear
275/35ZR19 26.54 overall inflated diameter
This seems to be the closest fit to the OEM sizes. I should have the tires on tomorrow morning. I'm hoping there is not too much tire bluge since I'm going to a 275 on an 8" rim. I'll take some pics to check out and let you guys know what I think in a few days. I really appreciate the assistance here.
Shane
Old Jan 24, 2007 | 12:54 PM
palepony's Avatar
palepony
275 is way to big for an 8" rim.
As per the nitto website, the ideal rim size is 9.5" and a MINIMUM of 9". Cancel your order, or get new rims if you want to run that size.
I'm sure you can make them fit, but why? They will not perform properly and handle worse.
Sounds like your tire guy is a retard.
pp
Old Jan 24, 2007 | 01:00 PM
JDMFairladyZ33
Originally Posted by palepony
275 is way to big for an 8" rim. Sounds like your tire guy is a retard.
As per the nitto website, the ideal rim size is 9.5" and a MINIMUM of 9". Cancel your order, or get new rims if you want to run that size. I'm sure you can make them fit, but why?
pp
+1 Crap I missed the 8" all the way around. You and your tire guy are retarded if you run 275s on an 8" wheel. That is very unsafe. Be prepare to be all over the road when you switch lanes. I don't understand why people think they can crame oversized tires on stock wheels or bought the wrong application. What's the offset for those wheels? Are they even for a Z? Seriously man, you need to take everybody's advice here or you'll learn the hard way.
Old Jan 24, 2007 | 05:14 PM
shanecrosby
Unfortunately, the rims came on the car. :-( I haven't really paid much attention to them since I had no problems so far. Now I'm looking at new tires and problems have come.
Old Jan 24, 2007 | 05:17 PM
shanecrosby
Lighten up on the retard sht, atleast with me JDMFairladyZ33. I started this thread to learn, not be criticized. Thanks in advance.
Old Jan 24, 2007 | 05:31 PM
JDMFairladyZ33
okay I'll take that back and apologize for the retard comment. What it was really ment for was your tire saleman. Do you realize that if you had put 275s on the rears and got into an accident they would be liable? The specs you've mentioned in your original post is considered dangerous. If you search deep enough you'll actually find a few individuals posting that they lost stability and control with oversized tires. It's pretty simple if you think about it. With an overhanging tire, the sidewalls have no support to handle the load of the car properly. In extreme cases the bead of the tire would actually roll off the wheel. Please do yourself a favor and spend a little bit of money if you want to go wider.
Old Jan 24, 2007 | 05:39 PM
shanecrosby
This is causing a real headache. I think I'll hold off and comb the classifieds for a wheel/tire combo. What I'd really like to find is a set of 18x8.5-9 front and 18x9.5-10 rear rims. I should be FI within 4 months (considering tax time!!!) and am just trying to get as much tread on the ground as possible. -To a certain extent. Thats why I was open to the idea of the 275's, not knowing the possible consequences. Hmmm... I am correct in going down to 18's for performance reasons, right?
Old Jan 24, 2007 | 05:42 PM
Reyes_USN's Avatar
Reyes_USN
I thought it was 225/45 fronts and 245/45 on rears?
Old Jan 24, 2007 | 09:46 PM
palepony's Avatar
palepony
I also apologize for the retard comment, but it was directed at your tire guy, not you. I do, however, seriously suggest going to another shop if this is what he was willing to do for you. That combination is very unsafe.
I would also suggest you read the FI forum more if you think "tax time" money is enough for FI. You need expendable cash for that game.
Reyes, I think Dave was suggesting the standard "upsize" would be 245/275, not standard "stock" size. I would suggest 255/275 myself as closer to stock size and reduces understeer.
pp
Old Jan 25, 2007 | 08:44 AM
shanecrosby
Thanks. I actually just sold my Accord which was paid off. Utilizing the $$ from both taxes and the sale to do this FI purchase and install.
Old Jan 27, 2007 | 04:14 PM
shanecrosby
Alright guys. I got new rims along with new tires so my fitment would be correct.
I went with Axis Shine's.
Front 19x8.5 26lbs
Rear 19x9.5 27lbs with 3.5" lip. I like the lip
Toyo TR1 tires
Front 245/35/19
Rear 275/35/19
I definately have more grip and I haven't even worn the shiney tire crap off yet...
Attached Thumbnails New tires and my VDC-imgp0816.jpg   New tires and my VDC-imgp0819.jpg   New tires and my VDC-imgp0821.jpg   New tires and my VDC-imgp0811.jpg
Old Jan 27, 2007 | 04:19 PM
JDMFairladyZ33
Looking good shane, fitment is dead on. Can't go wrong with your application.
Old Jan 27, 2007 | 04:35 PM
shanecrosby
I'm trying to upload a vid to photobucket for you guys to check em out when rolling. Plus the vid is funny IMO. -I'd been drinking and didn't want to drive it, so my buddy Matt did it for me. Have you ever let anyone drive your Z? Just seems they don't really know how. I won't show that unfortunate video with stalling and crap, but he did ok rolling it down the street. Vid is 50mb done with my digi camera so I can't really compress the file. It should be up later tonite when this dang Verizon wireless card hurrys its butt up.. Need cable modem...
Old Jan 27, 2007 | 04:37 PM
Scarab440's Avatar
Scarab440
wow those look great.
Old Jan 27, 2007 | 05:32 PM
shanecrosby
Vid
http://s20.photobucket.com/albums/b2...t=IMGP0830.flv
