Which big brake kits (if any) will fit/clear...
Old Jan 28, 2007 | 05:46 PM
GamblerZ's Avatar
GamblerZ
Default Which big brake kits (if any) will fit/clear...
...my Work Equip 19x8.5 +32 and 19x9.5 +26 ?
Old Jan 29, 2007 | 12:21 AM
ppw350Zunit's Avatar
ppw350Zunit
any pics of your car?
Old Jan 31, 2007 | 07:04 PM
GamblerZ's Avatar
GamblerZ
Anyone?
Old Feb 1, 2007 | 08:18 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
AP 4 pot, Stoptech 4 pot also has pretty shallow design -that's about it without knowing more info
Old Feb 4, 2007 | 06:36 AM
GamblerZ's Avatar
GamblerZ
Are there absolutely no others that will fit? It seems from their design (images below) that others could clear the wheels as well.
How does one determine whether one brand will fit and another not without test fitting first? There must be some way to compare measurement specifications of each. Otherwise, will the OEM Brembos fit?
Old Feb 4, 2007 | 07:22 AM
bb1314's Avatar
bb1314
da Terminator!
I have the same type of question too. I have WORK Meister S1 3PC. 19x9.5 + 19x10.5 and I wonder what BBK will clear/fit.
Old Feb 4, 2007 | 08:45 PM
Z1 Performance
Former Sponsor
there are alot of factors that determine what fits and what does not
I would recomend visiting the brake manufacturers sites, download and print the pdf files and you'll see exactly what will and wont fit
Old Feb 19, 2007 | 07:57 PM
GamblerZ's Avatar
GamblerZ
Will the OEM G35/350Z Brembos fit?
Old Feb 19, 2007 | 08:19 PM
thinking's Avatar
thinking
StopTech 4 pots stick out about 1.5" from the hub while Racing Brake 4 piston calipers are "only" about 1"
Go to StopTech's website print out a template. Take off your wheel and use the template to see if it clears. If not, go to Racing Brakes website, check their measurements and cut down the StopTech template to simulate the Racing Brake measurements.
Old Feb 19, 2007 | 08:32 PM
derekinthez's Avatar
derekinthez
Default Specs
You need to get a schematic of your rim with all its measurements and the same for the intended brake application--the schematic should be on the rim and brake's website
Old Feb 20, 2007 | 04:56 AM
davidf's Avatar
davidf
Stoptech along with other BBK co. usually offer clearance templates online to determine if your wheels will work with they're kits.
Old Feb 20, 2007 | 10:15 AM
StopTech's Avatar
StopTech
Vendor - Former Vendor
http://www.stoptech.com/tech_info/wheel_fitment.shtml
samansharif
Sep 25, 2015 12:31 PM
