2 quick tire/rim questions
Old Feb 1, 2007 | 11:38 PM
SeanMc300's Avatar
SeanMc300
Default 2 quick tire/rim questions
First thing first, i want to get new rims. im eyeing the Axis Milano's in F 19x8.5 and R 19x9.5. Thing is, the only offset i can find +15, +35, +45. I know the last two are out, but is +15 too low? The rear is +20.
Also, could i fit 285/35-19 on the rear (even tho they are 9.5 wide)?? Its on stock suspension so i know i wont rub.
Thanks in advance.
Old Feb 2, 2007 | 03:45 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
285/35 on a 19 with a +20 may or may not be ok it's certsaonly going to throw alignment way off, even on stock suspension (you'll have lots of toe in)
Up front, a +15 will work with an 8.5 just understand the negatives of moving the wheel and tire so far outward too - the biggest downside is the car tramlines much worse (follows all the grooves in the road), and you'll have increasd stressed being placed on all your suspension components and bushings
Old Feb 2, 2007 | 05:14 AM
You could use a offset calculator, and compare your present to new wheels. With the new numbers, you could check the car with a tape. Do you clear the calipers and fenders? But it is a headache to do it yourself.
Old Feb 2, 2007 | 06:05 AM
sluggoZ's Avatar
sluggoZ
Thanks in advance.
For the MIlano's you would want a +15 offset front & +20 offset for the rear on a Z.
For my taste I like the rear 275/35/19....almost certain to be free of any problems. 245/35/19 front. Some dealer's have the Milano's (now being discontinued) overpriced.
lapham3
Oct 7, 2022 03:15 PM
issyz
Jul 2, 2017 03:04 PM
