Ask the "Tireguy"
Old Apr 3, 2003 | 08:47 PM
arnelr21's Avatar
arnelr21
Default Ask the "Tireguy"
If you guys have any questions concerning wheels or tires, feel free to ask and I will do my best to answer them the best way I can. I am fornate enough to have the resources to research most wheel and tire concerns. Thanks.
Old Apr 8, 2003 | 11:06 AM
texlace's Avatar
texlace
Default Front tire cupping
My front tires are worn out a 7000 mi. Cupping on inside edge is very bad. Seems to be a typical problem. Do you know anything about a Nissan fix?
Thanks,
Don
Old Apr 8, 2003 | 04:18 PM
alex30327's Avatar
alex30327
I have the performance model with 18 inch wheels. Will the following set up work well with my car. I just purchased toyo TS-1 tires 245/45/18Front, 255/45/18 rear.
Old Apr 8, 2003 | 06:17 PM
Brando222's Avatar
Brando222
Ziologist
I have the Performance with tire pressure monitors, I just bought a set of Track Rims with the tire pressure monitors also on them I believe. Both are stock rims, they just come from different 350Z packages in case you don't know. Now do I have to switch the tire pressure sensors, or will the Track pressure monitors be automatically detected and useable by my cars computer?
Brandon
Old Apr 9, 2003 | 11:40 AM
Todd@ProDyno's Avatar
Todd@ProDyno
Hey Arn...hows biz?
Old Apr 11, 2003 | 07:12 AM
arnelr21's Avatar
arnelr21
It's not the recommended set-up. You'll be going with a larger diameter tire, but with all the wheel well space, it should work functionally. You can optimize the performance if you go with 245/40-18 fronts and 275/40-18 for the rears.
Old Apr 11, 2003 | 07:26 AM
mytalon's Avatar
mytalon
Will a 275 work safely on a 8.0 inch rim? what about a 8.5 in?
Old Apr 11, 2003 | 07:13 PM
arnelr21's Avatar
arnelr21
8" barely squeezes that baby in. 8.5-10" would be better. I'm going to be using 19 x 10's for my 275/30-19's .
