Help on tire sizing?
Here is some info to get you caught up, I have rim sizes 18X9.5 all around with a +12 offset. I cant decide what tires I should run on these, I was thinking 245/35/18 front and 275/35/18 rear. What tire size would you go with? Would a 245 fit on a 9.5 rim good or would it be strected to hell? Any suggestions would be great.
thanks in advance
Jonathan
thanks in advance
Jonathan
You have an advantage because you do not have to worry about VDC.
275mm is perfect for a 9.5 inch wheel. So a safe range is 275 plus or minus 20mm or 255 to 295mm. Within that range there are lots of possibilities.
Originally Posted by TuscaniJon
what about 245 on a 9.5 rim... I think that is my main concern.
i am also looking at this and this is what it says on the Nismoparts website
P245/40R18 (18 x 8.5 wheel) or P275/40R18 (18 x 9.5 wheel).
so 275 in the rear looks perfect but the front is definetely a concern
TireRack.com has good information under "Specs", if the tire you want is on their site. For example, this random Yokohama tire spec page shows 245/35 ZR18 fitting on rim widths of 8-9.5", and 275/35 ZR18 fitting on rim widths of 9-11".
