HELP!! ASAP!! Will Work VS-XX work with 28/29 offsets? Need answers/buying TODAY!!
Old Feb 25, 2007 | 03:11 PM
3FIFTYZEE's Avatar
3FIFTYZEE
Default HELP!! ASAP!! Will Work VS-XX work with 28/29 offsets? Need answers/buying TODAY!!
Im Planning on buying Work VS-XX rims today.
I need to know if these offsets and tires will work on a 2004 350Z. Will they stick out of the fender or be set in more? Will I have any rubbing??
Planning on buying adjustable coilovers also.
Size and offsets of rims:
Front - 19X9.5, +28 offset, 255/35/19 tires
Rear - 19X10.5, +29 offset, 275/35/19 tires
Old Feb 25, 2007 | 03:17 PM
gimpster621's Avatar
gimpster621
your fine
Old Feb 25, 2007 | 03:33 PM
sry110's Avatar
sry110
Sounds like you will have adequate space to fit them.
Old Feb 25, 2007 | 03:41 PM
3FIFTYZEE's Avatar
3FIFTYZEE
so will they be pretty flush with the fender or will the be set in pretty far? I usually see people go +22 offset. What would the difference be from +22 and and +28/+29??
Old Feb 25, 2007 | 05:16 PM
gimpster621
22 is ideal but 29 wont be bad with 9.5/10.5
ive had every possible width offset on my car. 10.5 et 29 will be pretty flush
Old Feb 25, 2007 | 05:19 PM
MR_X's Avatar
MR_X
worst case if you need them to come out, get you some spacers.
Old Feb 26, 2007 | 04:52 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it won't sit perfectly flush, but will look just fine.
If you find its not set out far enough, you can get spacers - the more you bring them up, the more you'll need more camber correction
Old Feb 28, 2007 | 03:10 PM
VIP-STATUS's Avatar
VIP-STATUS
This offset is made just for the G35+350Z.
Old Feb 28, 2007 | 06:11 PM
jinsei888's Avatar
jinsei888
easy fit
