Weight Reduction: can this be correct?
Old Mar 1, 2007 | 06:21 AM
goodkd's Avatar
goodkd
Default Weight Reduction: can this be correct?
I'll be getting the Z out of winter storage soon - considering going on a small diet (i.e., remove spare, get low weight battery, empty wiper fluid, etc. and maybe move to lightened flywheel and exhaust eventually).
So, I wanted to see how much weight I added by upgrading wheels (19" TE37s).
Upon a quick search I found this:
rear stock (17"): 24 lb rim and 29 lb tire for a total wt. of 53 lbs.
rear now (19" TE37 with Toyos): 21 lb rim and 28 lb tire for a total of 49 lbs.
To my amazement, it looks like I actually saved a few pounds per wheel! I'm looking for a reality check - is my data, which is from the web, not my personal measurements, reasonable?????
Thanks
Kev
Old Mar 1, 2007 | 06:27 AM
kwiker's Avatar
kwiker
Shift_Dorifto
Yes, that is probably correct. Weds tc105n FTWS(for the weight savings)
Old Mar 1, 2007 | 07:40 AM
drumma022's Avatar
drumma022
Here is a rear 19x10.5 with a 275/35/19 Toyo T1R weighing in at 49.9lbs.
Attached Thumbnails Weight Reduction: can this be correct?-dscn1912.jpg
Old Mar 1, 2007 | 07:43 AM
One wheel is cast and the other is forged. Think about it.
Old Mar 1, 2007 | 07:44 AM
goodkd's Avatar
goodkd
Ok, cool - looks like the values I found on the web are reasonable - I may not have saved much weight, but at least I didn't ADD any!
Kev
Old Mar 1, 2007 | 07:46 AM
goodkd's Avatar
goodkd
Typical reply for this forum.
I understand one is cast the other is forged. The one that is forged happens to be signifanctly larger smarty.
Old Mar 1, 2007 | 07:53 AM
Thumbs up
Its bigger but weighs less. Beautiful wheel BTW.
Old Mar 1, 2007 | 08:08 AM
davidf's Avatar
davidf
Jesus thats a sexy wheel.
Old Mar 1, 2007 | 08:27 AM
DavesZ#3's Avatar
DavesZ#3
Thanks
Kev
You'll definitely save weight - I did. I went from the stock 18" wheels and OEM tires (53/57lbs) to 19" LE37Ts with Michelin PS2s (44/48lbs).
Old Mar 1, 2007 | 09:27 AM
redlude97's Avatar
redlude97
You saved some weight, but moved a majority of it away from the center of rotation, this requires a greater wheel torque to spin it so your gains are probably being offset by the larger size. Don't expect any differences in acceleration
Old Mar 1, 2007 | 10:21 AM
first350's Avatar
first350
+1! It's all about the polar moment of interia.
Old Mar 1, 2007 | 10:54 AM
kwiker's Avatar
kwiker
Shift_Dorifto
That just sounds really cool and makes me want smaller wheels even though i don't have any idea what you are saying.
hahahaha, just kidding...i kinda understand.
Old Mar 1, 2007 | 01:13 PM
Mazinger Z's Avatar
Mazinger Z
Yep that is correct. My le28n's are 19x10.5 in the rear w/ Toyo ts1's and weighed in at 46lbs. I think my stock 18x8.5 were 53lbs or something.
Old Mar 1, 2007 | 02:28 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
Unsprung weight FTMFW!
Old Mar 1, 2007 | 02:34 PM
jondimellow's Avatar
jondimellow
nerd. haha.
Old Mar 1, 2007 | 02:35 PM
goodkd's Avatar
goodkd
Yea, I figured. When I originally set out, I wanted to see how much wieght I added. I was surprised that I hadn't added any. But, I didn't get too exicted about the so-called reduction becuase I new I had less weight overall, but more weight distributed further out.
Old Mar 1, 2007 | 02:43 PM
goodkd's Avatar
goodkd
Sprung or unsprung - all wieght is the enemy
Old Mar 1, 2007 | 03:08 PM
DavesZ#3's Avatar
DavesZ#3
I was concerned about the same thing, but after doing some rough calculations, with my weight savings, the inertia before and after worked out about the same. In other words, the mass moved farther out, but the lower mass cancelled out the radius change.
Old Mar 1, 2007 | 03:20 PM
redlude97's Avatar
redlude97
I agree, thats why I said don't expect any changes in acceleration, should be roughly the same moment of inertia
Old Mar 1, 2007 | 07:33 PM
Wholey Smokes's Avatar
Wholey Smokes
Originally Posted by jondimellow
nerd. haha.
LOL
