//////<<<---SSR /// Wheels Thread!--->>>/////
Old Apr 20, 2012 | 07:25 PM
  #381
Ruthless18x's Avatar
Ruthless18x
Looks good!
Old Apr 21, 2012 | 02:40 PM
  #382
Waiz's Avatar
Waiz
Looks good!
Where are those installed pics of your SSR's Shane? Get cracking!
Old Apr 25, 2012 | 07:21 AM
  #383
mike_d's Avatar
mike_d
Default SSR Type-Fs !
After a long wait I finally got in my Type-Fs.
I am a littler concerned about the front. It looks like the wheel/tire is poking out almost a 1/2 inch from the top of the fender. I havn't driven it yet but I'm assuming the fronts poking out this much will rub. My guess is I'll need around -2 degrees of camber in the front to make this work. Thoughts?
I know there are some guys in here running the 10.5 +15 up front. A 9.5 +12 wheel should sit about 10mm deeper in the wheel well then the 10.5 +15. So maybe I shouldn't be concerned at all.
I have KW v2's and SPL front and rear arms waiting to get installed too!
Specs:
18x9.5 +12 265/35
18x10.5 +15 285/35
Attached pic is obviously at stock height.
Attached Thumbnails //////&lt;&lt;&lt;---SSR /// Wheels Thread!---&gt;&gt;&gt;/////-type-fs_stock-1.jpg
Old Apr 25, 2012 | 07:48 AM
  #384
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
Once you get your coilovers and camber parts installed you will probably be fine. How low you go will determine how much camber you'll need to not rub. Those are some beefy tires so you may not be able to slam it. However, because of how beefy they are it doesn't look like you're trying to be "low n slow".
Old May 6, 2012 | 09:13 AM
  #385
Jose2008Z's Avatar
Jose2008Z
Specs:
18x9.5 +12 265/35
18x10.5 +15 285/35
Hey Mike...you'll be just fine after you lower the car and add a little camber. I have a 10.5 front at +15 and i'm running -2.7 degrees of camber
Old May 9, 2012 | 10:47 AM
  #386
TheDangerZone's Avatar
TheDangerZone
you'll be fine. a lot of guy are running those specs in front.
Old Jun 4, 2012 | 12:12 PM
  #387
joshie3.5.0.z's Avatar
joshie3.5.0.z
hey have you had any rubbing problems yet? i plan on ordering the same rims with the same offsets different color, but i was worrying about the offset up front , im at stock height i plan on lowering my car and maybe running a stretched tire when i lower it , i dont plan on getting a camber kit any advice?
Specs:
18x9.5 +12 265/35
18x10.5 +15 285/35
Old Jun 4, 2012 | 12:20 PM
  #388
joshie3.5.0.z
you wouldnt happen to know what offsets the gray z is running? and if he has fender work
Originally Posted by Waizzz
^Awesome
These are from the other night.
The NISMO has 19" Type F's and the 350z has 18" Type F's
Old Jun 4, 2012 | 12:23 PM
  #389
joshie3.5.0.z
do you have any fender work done?
Originally Posted by rubicant
Here's my setup:
SSR Type F
Matte black
18x10.5 +15 all around
Hankook RS-3 275/35/18 all around
Ground isn't leveled, so front looks way lower and back looks way higher!
A bit too low to drive anywhere, but I like it! Going to raise it a tad in the front.
Old Jun 4, 2012 | 12:47 PM
  #390
Waiz's Avatar
Waiz
Please don't quote photos strings in posts, just quote the post itself.
Your question to me was already answered in the above post that you quoted regarding sizing.
Rubicant will chime in regarding his fenders, I believe they were only rolled flat and not pulled but he will be able to confirm.
Old Jun 11, 2012 | 01:16 PM
  #391
dvo's Avatar
dvo
rubicant is running 10.5 +15 on 285s all around and he's golden. His car isn't slammed like it used to be though.
Old Jun 12, 2012 | 07:22 AM
  #392
D&G35's Avatar
D&G35
Old Jun 12, 2012 | 07:49 AM
  #393
graffkid732's Avatar
graffkid732
Originally Posted by D&G35
Both are beautiful in their own ways.
Old Jun 12, 2012 | 08:59 AM
  #394
D&G35's Avatar
D&G35
Thanks...
Old Jun 12, 2012 | 10:09 AM
  #395
Ruined Z's Avatar
Ruined Z
The only fender work done is in the rear; rolled and a tiny pull, but as DVO said, it was lower before. Also, I was running Work VS-XX 19x11 +0 in the rear, so that's why it was slightly pulled. You will probably just need a regular roll in the back.
The front rubs the fender liner, but that's about it.
Do you plan to run any camber at all? I am at -2.5 all around. Going to decrease it in the rear to -1.5 soon.
Old Jun 12, 2012 | 10:59 AM
  #396
D&G35's Avatar
D&G35
i've run 20x11 with a -11 rear offset before with only a roll and NO pull..tires were stretched on 265/30's...no rubbing issues
Old Jun 24, 2012 | 08:00 PM
  #397
Waiz's Avatar
Waiz
Here are a few pics of FRESHZ's 19" SP1's in SBC
Old Jun 24, 2012 | 08:04 PM
  #398
alfhasg35's Avatar
alfhasg35
Mr. WAIS.. I believe those are SP1's..
Either way.. Wheels are the shiZZo..!!!
Old Jun 24, 2012 | 08:08 PM
  #399
alfhasg35's Avatar
alfhasg35
Here is my old wheels on the new owners 370..!!
Old Jun 24, 2012 | 08:09 PM
  #400
FRESH Z's Avatar
FRESH Z
Pics came out great Waiz!
