dremel to shave off fender,
Old Mar 7, 2007 | 04:13 AM
emulzhn's Avatar
emulzhn
Default dremel to shave off fender,
has anyone used a dremel tool to shave off the inside of fenders?
Is there a reason why the nissan left the rears unrolled?
does the integrity/ shape of fender deteriorate on rolled/ shaved fenders?
planning on 295/35/19 with 18 offsets....
Old Mar 7, 2007 | 04:37 AM
emulzhn's Avatar
emulzhn
Default fenders rolled
you're right...
certainly don't want rust...however there are some feelings that shaving is better. can't imagine this as difference is minimal...or is there.
Old Mar 7, 2007 | 04:55 AM
sq40's Avatar
sq40
Its not that expensive to have a shop roll them for you correctly. Lord knows we all like to DIY, but sometimes the cost/benefit is well in the favor of having a pro do it.
Old Mar 7, 2007 | 08:34 AM
MR_X's Avatar
MR_X
if you cut that part of the fender, you might weaken the fender making it flex. That lip add rigidity to the panel. So just go and get it rolled.
Old Mar 7, 2007 | 09:01 AM
Motormouth's Avatar
Motormouth
even a pro can crack it....
and paint will most likely ship off anyway.... paint just isn't made to deform that much, esepecially on a sharp edge. you can treat the edge with a clear coating that prevents rust. and the primer should stay intact.
but then there are guys that have rolled and the paint has been fine.
Old Mar 7, 2007 | 01:01 PM
teamsprock's Avatar
teamsprock
I've rolled my fenders using my Eastwood fender roller and torch and have no paint chipping problems. You just need the paint warm and unless your doing a pull its really not that hard. If you just need a small roll just use a baseball bat. And roll it between your tires and the fender. This works fine and if you use a wood bat avoids hurting the paint. Look at Freshalloy.com if you want to see how the 240sx people do it.
Cutting them also reduces the strength of the fender.
Old Mar 7, 2007 | 01:02 PM
Jay'Z's Avatar
Jay'Z
Roll em pls!!
Old Mar 8, 2007 | 05:25 PM
Wholey Smokes's Avatar
Wholey Smokes
I had mine cut. No big deal.
Old Mar 8, 2007 | 06:04 PM
DHCrocks's Avatar
DHCrocks
I can't imagine how long it would take to dremel it off. use a nibbler or grinder it will go much faster.
Old Mar 8, 2007 | 10:26 PM
Korki Buchek's Avatar
Korki Buchek
Chainsaw is even better.
Old Mar 9, 2007 | 02:10 AM
emulzhn's Avatar
emulzhn
any problems with ones cut or shaved off..any pics..pls....
Old Mar 9, 2007 | 03:06 AM
bam025's Avatar
bam025
Yea found a shop to cut mine for 30 bones.
Old Mar 10, 2007 | 02:08 AM
Chad68's Avatar
Chad68
I agree, that's why I'm going to grind a tad off mine when I get the 305's on next month Primer and touch up paint will do wonders to prevent rust.
Old Mar 12, 2007 | 03:10 PM
L33TZOR's Avatar
L33TZOR
i had learned how to make use of the fender roller tool a few weeks back.
a friend and i did a 350z, g35 and a 330ci in one sitting.
once you do it one time, its cake. a heat gun (people are using torches too) and the fender rolling tool can give you the right clearance depending on what tire you are installing.
Old Mar 12, 2007 | 03:20 PM
JonnyRod's Avatar
JonnyRod
does anyone have pictures of this?
Justin100
Nov 25, 2021 06:26 AM
StateNuke08
Oct 31, 2015 05:01 AM
Mikey3288
Mid-Atlantic Marketplace
Oct 23, 2015 07:41 AM
Dymsi
Sep 29, 2015 11:32 AM
