tread wear on toyo t1-s
Old Mar 12, 2007 | 10:32 AM
ldawg32's Avatar
ldawg32
Default tread wear on toyo t1-s
approx how many miles should i be getting out of these. very unargressive driven. no burnouts just regular driving around town cruising. had on for about 17k. mechanic said my fronts are showing a tiny bit of metal wire. i baby my car and cant believe i need new tires already. i garage in winter and my car only has a total of 24,000 miles. bought rims and tires in early 2004. btw these are the front tires that i need rears needed soon though
Old Mar 12, 2007 | 11:40 AM
aznmojo's Avatar
aznmojo
sounds like its the feathering issue
Old Mar 12, 2007 | 11:46 AM
John's Avatar
John
Treadwear ratings are irrelevant as they are unique to each manufacturer... I probably have about 20k miles on my T1S street tires and I'd say I have 40% tread left (and would have more but I put two track days on them when I didn't have R-compounds available). There could be a lot of things that would cook your tires prematurely, usually a less than perfect alignment (especially toe) is the cause.
Old Mar 12, 2007 | 01:19 PM
ldawg32's Avatar
ldawg32
yes it has to be the tire feathering prob. i thought if you had bigger wheels it would fix itself. i thought i heard that a while ago but dont remember. oh well. new t1r's on the way for tomorrow. ill be replacing all four and getting a wheel alignment. soon i will be selling the rear tires as they are not worn as much as he thought at the time. look for a FS: thread for new rears if interested thnx again guys. wish i payed more attention 3 yrs ago would have saved myself $1K for now.
what does (especially toe) mean. is that the prob with the tire feathering issue
Old Mar 13, 2007 | 07:30 AM
John's Avatar
John
Tire feathering didn't affect the rear, and you can tell if your car was plagued with it if the inside of the front tires wore unevenly. Another indicator would have been the tire noise as your car would sound like a truck...
Definition of toe: http://en.wikipedia.org/wiki/Toe_%28automotive%29
Old Mar 13, 2007 | 07:45 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Post some pics if you can. Your problem may also sound like a simple wear alignment issue which is different from feathering. Even though some feathering can be corrected with alignment adjustment, the root cause may be different.
Old Mar 13, 2007 | 08:00 AM
The Brickyard Rat's Avatar
The Brickyard Rat
Have about 15,000 miles on my T 1Rs with another 10,000 or so left.
Old Mar 13, 2007 | 10:22 AM
ldawg32's Avatar
ldawg32
yeah its justr the inside of the fronts. they are worn unven. i am getting new t1-rs on today and will post pics of old tires. the rears look fine and i will be selling as of later today.
emooheo
Oct 14, 2015 08:58 AM
