Are these wheels going to make it?
Old Mar 13, 2007 | 05:23 PM
Theatrix's Avatar
Theatrix
Professional
Default Are these wheels going to make it?
S1's....11's with +17 offset in the rear and 9.5 with a +24 in the front.
PS2's 305x30x19 (R) and 265'sx35x19 (F)
with rolled fenders and adjusting arms front and rear.
Not sure if its going to fly!
Old Mar 13, 2007 | 05:24 PM
2005daytonaZ's Avatar
2005daytonaZ
negative camber will be your best friend.
Sean's Avatar
Sean
if your rims are out that much, rock chips will eat your black paint
Old Mar 13, 2007 | 05:29 PM
05-Z's Avatar
05-Z
Are you lowered?
aznmojo's Avatar
aznmojo
go with some falkens, negative camber the **** out of it and u got urself a VIP ride.
Old Mar 13, 2007 | 05:33 PM
Theatrix's Avatar
Theatrix
Professional
Originally Posted by 05-Z
Are you lowered?
KW Variant 3's going on.
I should qualify this by saying that the car is getting a widebody and these were intended to be interim wheels until that happens. Initially I was thinking that we would go with 12's when that happens, but it looks like we could live with these sizes.
Old Mar 13, 2007 | 05:34 PM
djnc's Avatar
djnc
with 305's in the rear...no way...you'll need stretched tires and mad negative camber
Old Mar 13, 2007 | 05:47 PM
sofa king's Avatar
sofa king
those ****s are baller!
Old Mar 13, 2007 | 06:00 PM
Ichigo's Avatar
Ichigo
Nice rims man, real nice
drumma022's Avatar
drumma022
KW's V3 don't really go that low, however check out Zexy's posts with his S1's 11" wide and you will see what camber/lowered will do for you.
I also recommend putting 1 jack under the lower control arm to simulate weight on the car.
Old Mar 13, 2007 | 06:09 PM
twotonetrack's Avatar
twotonetrack
Some of the best looking wheels I have seen. What are they?
Old Mar 14, 2007 | 07:06 AM
Theatrix's Avatar
Theatrix
Professional
Works S1's...............but I think I may have to set aside the rears until the widebody goes on. Camber kit may help, but I don't want to wear out the tires in 8k either. Not at 400+ per tire.
I'll have to re-order 10.5 +24 for the rears to solve the problem for now.
Unless I'm missing something here, chime in if I am.
Old Mar 14, 2007 | 07:11 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
I've always like the Work S1s. They'll look super clean on the roadster.
Old Mar 14, 2007 | 07:15 AM
davidf's Avatar
davidf
Agree, the the wheels will set in some with the weight setting down.
Old Mar 14, 2007 | 08:16 AM
drumma022's Avatar
drumma022
Here is Zexy's car on 9.5 Front and 11 Rear with a 255/275 tire combo - camber - lowered.
Old Mar 14, 2007 | 08:20 AM
JDMFairlady21's Avatar
JDMFairlady21
theatrix it'll be fine trust me! if anything it'll poke out a mm or two but nothing crazy... just slap em on and set the car down you'll see..
Old Mar 14, 2007 | 09:03 PM
Triple8Sol's Avatar
Triple8Sol
Interesting that you went with an overly aggressive rear wheel fitment (width/offset), then went with a conservative fitment in the front. You could've gone wider, or at least gone with a lower offset to match the rear...
Old Mar 14, 2007 | 10:53 PM
Gruppe-S's Avatar
Gruppe-S
Vendor - Former Vendor
You can try machining down the rear a bit, but you'll probably still be out a little far. It can work, but as sean1967 said, your paint is going to pay the price, especially if you get sticky tires.
Good luck!
Gary
Gruppe-S
HoBrahYouStink
Jun 24, 2016 10:58 PM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
samansharif
Sep 25, 2015 12:31 PM
