Tires size recommendation...
Old Mar 15, 2007 | 07:33 PM
Dubai's Avatar
Dubai
Exclamation Tires size recommendation...
Since traction is a b|tch to get with my setup I thought of changing my rear tires which are 275/35/19 to some wider ones.
heres my question, I have 10.5 wheels at the back with 19 offset. I have ONLY two options since thats whats available at the moment, either Michilen PS2 285/35/19 or 295/30/19. which one do you guys recommend and why?
Old Mar 15, 2007 | 07:41 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
OEM RE040 rolling diameter (validated from Bridgestone's application chart)
F 225/45/18: 25.9"
R 245/45/18: 26.6"
Michelin PS2 rolling diameter (validated from Michelin's application chart)
295/30/19: 26" <-- Close but too short
285/35/19: 26.9" <-- This is closer
305/30/19: 26.25" <-- This would be option 2 for me. May have to roll and cut fenders.
Old Mar 15, 2007 | 07:49 PM
Dubai's Avatar
Dubai
305/30/19 is also another option. rolling/cutting the fenders is not a big deal. anybody running them?
Old Mar 15, 2007 | 07:50 PM
Dubai's Avatar
Dubai
BTW JDMFairladyZ33, have any pics of your current wheels/tires setup?
Old Mar 15, 2007 | 08:28 PM
JDMFairladyZ33
Yeah but they are not very good ones I'll take some tomorrow and post them up.
Old Mar 16, 2007 | 08:55 AM
Dubai's Avatar
Dubai
bump. anyone running 305/30/19 tires?
Old Mar 16, 2007 | 10:27 AM
PHARM Z's Avatar
PHARM Z
Seriously, I would love to see that tire size. Damn man you live in Dubai? That's tight.
Old Mar 16, 2007 | 11:25 AM
Nihilation's Avatar
Nihilation
What do you plan on running in the front? I'd recommend the 255/35/19.
You may want to check about fender clearance when running larger than a 275 on the rear wheels with those offsets. I thought a 285/35/19 was a VERY tight fit.
A 285 would throw off your speedo a little(it'll read slightly slower than you're actually traveling). But it may increase traction more than a wider and smaller diameter tire. Think of it as artificial gearing. I vote 285/35/19.
If you still have traction issues change your gear ratio to a 3.3 like Alberto did. Have the rear alignment checked for thrust angle and toe as well.
kyin
Oct 15, 2015 05:54 AM
