Urgent Questions before I buy.
Old Mar 22, 2007 | 12:55 PM
Kolia's Avatar
Kolia
Originally Posted by _NIZMO_
I just talked to tirerack and the infromed me that the 255/40/18 may cause problems, and that the widest I could go was 245/40/18. Without causin any problems to the speedo.
Not ordered yet ?
What tires are these ? I doub't they'd cause a problem
The speedo uses the signal from all 4 wheels to figure out the car's speed.
Old Mar 22, 2007 | 12:56 PM
_NIZMO_'s Avatar
_NIZMO_
and that is for the front wheel incase your wondering
Old Mar 22, 2007 | 12:57 PM
_NIZMO_'s Avatar
_NIZMO_
Originally Posted by Kolia
Not ordered yet ?
no there ordered, but I just got a little worried, thats why; I am asking.
Old Mar 22, 2007 | 01:09 PM
_NIZMO_'s Avatar
_NIZMO_
Not ordered yet ?
Bridgestone Potenza RE050A
Old Mar 22, 2007 | 03:09 PM
_NIZMO_'s Avatar
_NIZMO_
so I should be ok write even though tirerack man told me I'm ****ed.
Old Mar 22, 2007 | 03:47 PM
Scarab440's Avatar
Scarab440
they allways do that. if the fitment isn't in their list of approved combo's they have to call and say so. no refunds due to fitment if they call you which makes the research so important
Old Mar 22, 2007 | 04:26 PM
_NIZMO_'s Avatar
_NIZMO_
so I take it I'm good b/c you just confused the sh_it out of me, lol.
Old Mar 22, 2007 | 07:51 PM
_NIZMO_'s Avatar
_NIZMO_
Bump
Old Mar 23, 2007 | 07:57 AM
Kolia's Avatar
Kolia
I've just checked the Bridgestone web site for tire sizes.
The 255/40R18 are 26.1in in diameter vs the recommanded tires' (225/45R18) of 25.9.
Comaparing with the 275/40R18 rear, the tire size difference will be 1.9% instead of the original ~3%. That is not enough difference to upset the ABS/VDC/TCS system as it's pretty much equivalent to running used rear tires with new fronts.
It's not the recommanded tire sizes, but it can still work AND will minimise the car's killer understeer that you'd get with a 245/275 combo.
Somebody else chime in so we can get this guy to order the wheels!!!! lol
Old Mar 23, 2007 | 08:17 AM
GolfinZ's Avatar
GolfinZ
Get the 255/275 35 combo. Mine isnt lowered yet and still looks fine. I havnt had any problems with ABS/TCS
Old Mar 23, 2007 | 08:46 AM
NaNa-Papa-J's Avatar
NaNa-Papa-J
Yea, don't worry about the Tire Rack doofus...he's required to downplay any setup not approved in their database. I run 255/35/18 in the front and 275/35/18 in the rear and have had absolutely no issues. You should be just fine...post pics when you're done. GL!!
Old Mar 23, 2007 | 11:09 AM
hockiman90's Avatar
hockiman90
i just bought the same thing except P45R's all around....before i bought i did alot of research and prob looked at most every thread realting to wheels on this site and other Z sites.....it seems that the computer(VDC) works fine with a similar DIFFERENCE between the front and rears inchwise, the speedo will prob be a bit off but who cares no one on this site obeys speed limits within a couple mph anyway ......but anyways ive found out that the most common combo with this size wheel seems to be a 265/35/18 up front and 285's in back...it also seems most logical with the tire sizes seeing as the difference between the front and backs are 0.3 inches which is the same as the stock ones
Old Mar 23, 2007 | 11:49 AM
NA&CH's Avatar
NA&CH
Are you getting the aggressive looking setup. The offset. I love the way the torques are concave...
Where in FL??
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
