wheel spacer questions
Old Mar 21, 2007 | 05:37 PM
azula's Avatar
azula
Default wheel spacer questions
i wanted to know what brand of wheel spacers i can purchase while maintaing the wheel being hubcentric. by that i mean, i don't want the lugs to be the only things holding the wheel. which wheel spacer is the "volks" of the industry? and where can i find them? thanks guys.
Old Mar 21, 2007 | 06:57 PM
terrasmak's Avatar
http://www.ichibausa.com/ thats all you need to know.
Old Mar 21, 2007 | 07:19 PM
redlude97's Avatar
redlude97
What wheels are you using them on and are you looking for spacers that replace the studs or bolt over the top of them?
Old Mar 21, 2007 | 07:32 PM
azula's Avatar
azula
^i have no idea, and i have iforged 20 inch wheels....which method would be safer? replacing or bolt over?
Old Mar 21, 2007 | 07:35 PM
azula's Avatar
azula
thanks a lot for the site, that really does explain everything
Old Mar 21, 2007 | 10:06 PM
Dubai's Avatar
Dubai
I'm using the H&R spacers for over a year now with no problems. either on the street or at the track its great and its hubcentric.
Old Mar 21, 2007 | 10:20 PM
GhostFace's Avatar
GhostFace
i reccomend Kics Project Wheel Adapters, evasive motorsports sells them and makes them hubcentric for you too, very high quality
Old Mar 21, 2007 | 10:57 PM
350ztoronto's Avatar
350ztoronto
+1 on the kics project i had h & r hubcentric spacers 20mm all around on my Z no probs but the install was $$$$$$$$
Old Mar 22, 2007 | 06:05 AM
Vlad's Avatar
Vlad
Am I right to think that longer studs are stronger and less weighting solution?
But how do you install longer studs?
Old Mar 22, 2007 | 06:26 AM
azula's Avatar
azula
h&r and ichiba are basically the same thing right? I mean...they have the same 'how to measure' graph on their sites.....I was thinking about goin with ichiba which is y i'm askin....
Old Mar 22, 2007 | 07:48 AM
z-u-later's Avatar
z-u-later
I'm using H&R Trak spacers, 20mm in front & 25mm in rear. I've driven on HPDE & auto-x events with no problems. I still have '06 stock tires & rims and they're flushed with the spacers. Here are pics of my Z from a recent auto-x event (I have ~1" drop):
Attached Thumbnails wheel spacer questions-silverstone_z.jpg   wheel spacer questions-autox_2.jpg
Old Mar 22, 2007 | 07:58 AM
Vlad's Avatar
Vlad
What model of H&R spasers do you use? DRS?
How difficult is to install new studs?
Thanks
Old Mar 22, 2007 | 08:38 AM
azula's Avatar
azula
Thanks
+1
DRS Series - (14-30mm Track Widening) - This spacer is fitted between the wheel and hub, exchanging the existing wheel studs for longer ones (Included). The wheels are fitted with the existing wheel nuts. (5 Bolt Only)
DRM Series (14-130mm Track Widening) - This spacer is fitted to the hub with special nuts and it carries new wheel studs for the existing wheel nuts. DRM Series spacers with track widening greater than 64mm apply to 911 only. (5 Bolt Only)
Old Mar 29, 2007 | 07:16 PM
azula's Avatar
azula
and also its wierd, i think my wheel indents into my fender MORE in the front than in the rear......is that common? i'll measure for sure in the morning but it looks like i am correct.....
Old Mar 29, 2007 | 08:33 PM
Volk350Z's Avatar
Volk350Z
Master
you can get Kics spacer with hub centric ring
Old Mar 30, 2007 | 02:36 AM
azula's Avatar
azula
yea, but why get those when spacers like ichiba and h&r already come hubcentric? i want to eliminate the extra peices that i'm assuming the kics come with...also have you ever seen a case in which the front wheels are further under the fender as opposed to the rear wheels?
Old Mar 30, 2007 | 05:38 AM
Vlad's Avatar
Vlad
So can you guys confirm that I DON'T NEED hub rings when using ichiba spasers?
Old Mar 31, 2007 | 04:20 AM
azula's Avatar
azula
^affirmative
_koubie_
Sep 20, 2015 06:34 PM
torchkc
Sep 11, 2015 08:26 PM
