if you know offsets, come hither
Old Mar 28, 2007 | 07:33 AM
ke0ki2k's Avatar
ke0ki2k
Default if you know offsets, come hither
will 18x10+38 fit up front running 265/35 tires on stock suspension? will it look good?
Old Mar 28, 2007 | 08:05 AM
BloMyS14's Avatar
BloMyS14
Might fit without hitting suspension... wouldn't look good. Maybe with an offset around +18
Old Mar 28, 2007 | 08:10 AM
97supratt's Avatar
97supratt
10" rim and a +18 offset will probably need fender rolling.
Old Mar 28, 2007 | 08:20 AM
Ghost 350z's Avatar
Ghost 350z
+20-+22 will be fine. I run +22 all around
Old Mar 28, 2007 | 09:34 AM
redlude97's Avatar
redlude97
How do you roll a fender that comes prerolled from the factory
Old Mar 28, 2007 | 10:19 AM
ke0ki2k's Avatar
ke0ki2k
but with the +22 offset it'll fit fine, no modifications?
Old Mar 28, 2007 | 10:23 AM
plastiketa's Avatar
plastiketa
Doesn't offset really depend on the spoke design? I've heard of folks of the boards running all sorts of +/- offsets but the wheels were all different brands and designs.
What wheel are you planning on running?
Old Mar 28, 2007 | 10:50 AM
ke0ki2k's Avatar
ke0ki2k
trying to decide between Enkei RPF1 or RPO3...id like to run the same size all around so i could rotate tires and save me some rubber, plus apparently stiffening the sidewall up by runnin 265's on 10 or 10.5 inch rims is beneficial.
Old Mar 28, 2007 | 11:50 AM
97supratt's Avatar
97supratt
Who said the 350z's are prerolled? I rolled my rear.
Old Mar 28, 2007 | 11:54 AM
dubbzdiggler's Avatar
dubbzdiggler
You have to have the rear tires be taller than the front ones. That's the way it's set up from the factory...if you don't, it'll throw off the drivetain and mess up the traction control.
Old Mar 28, 2007 | 12:12 PM
redlude97's Avatar
redlude97
He's trying to fit that on the front of his car
Old Mar 28, 2007 | 01:26 PM
97supratt's Avatar
97supratt
Last time I checked, you could roll the front fenders on a Z.
Old Mar 28, 2007 | 01:48 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
no you don't
there is nothing to roll up front
an 18x10 is going to look the same (in terms of where it sits in relation to the body) as a 9 inch wheel with a +25
Old Mar 28, 2007 | 02:13 PM
ke0ki2k's Avatar
ke0ki2k
...mmk..no more responses for you. The track and grand touring come setup that way, base and enthusiast models come 18 front and rear. Go read up on the specs and get back to me.
Old Mar 28, 2007 | 02:27 PM
Z1 Performance
Former Sponsor
The tires that come from the factory have zero impact on VDC, or traction control, or handling...there are rules with respect to front to back stagger that have to be adhered to in order to keep these things happy (within 3 % of overall diameter front to back), but you absolutely do not need to have different height from front to back.
just read the reply above.....I misread what you wrote ke0ki2K - you are correct!
Old Mar 28, 2007 | 02:45 PM
97supratt's Avatar
97supratt
Gotcha, thanks for the info, just the rear then.
Old Mar 28, 2007 | 03:19 PM
1nate7's Avatar
1nate7
I'd go with the RPF1 9.5 +15 all around. It's about as aggressive for the rear as you can get without causing problems up front. It's also plenty wide if you are just going to run 265's and would even give them a very slight stretch.
Old Mar 28, 2007 | 05:00 PM
redlude97's Avatar
redlude97
Base and enthusiast models come with staggered tires as well BTW, maybe you should stop responding
Old Mar 28, 2007 | 05:07 PM
ke0ki2k's Avatar
ke0ki2k
yes i know this, he was talking about wheel height, not tire size. I dont have TCS of VDC by the way, so i dont have to worry about messing that up. Just to clear everything up i have a 2006 350Z BASE COUPE..18x8.5 rear 18x8 front...
Old Mar 28, 2007 | 05:46 PM
redlude97's Avatar
redlude97
read his post again, he makes no mention of wheel height, only tire height
