_____urgent ?______
Old Mar 30, 2007 | 06:12 PM
_NIZMO_'s Avatar
_NIZMO_
Default _____urgent ?______
I just got my rims, but before I put them on I have a quick question. The ones I got are 9.5 all around but with 255 front and 275 rear. My question is; is it wrong hat I got the same rim size all around. B/c the factory wheels are diff in size for the front and rear.
Old Mar 30, 2007 | 06:29 PM
Scarab440's Avatar
Scarab440
should be fine with the same size rim on all cornners. Its the tire sizes that matter.
Old Mar 30, 2007 | 06:30 PM
_NIZMO_'s Avatar
_NIZMO_
Oh and what are these, the feel like plastic, so I don't think they are spacers, should I even use spacers.
Old Mar 30, 2007 | 06:35 PM
CaliTouring's Avatar
CaliTouring
what is that^^^
Old Mar 30, 2007 | 06:37 PM
No.
Old Mar 30, 2007 | 06:38 PM
timmays350's Avatar
timmays350
hubcentric ring use them. it just makes sure the wheel is centered on the hub properly
Old Mar 30, 2007 | 06:40 PM
I think you might want to put those on the car.
Old Mar 30, 2007 | 06:46 PM
_NIZMO_'s Avatar
_NIZMO_
is it dangerous that they are plastic and plus do I need to use spacers
Old Mar 30, 2007 | 06:55 PM
No.
I doubt it. Do the wheels clear the brake callipers? Do the tires rub the suspension?
Old Mar 30, 2007 | 07:07 PM
HDPDZO6's Avatar
HDPDZO6
The need for spacers depends on the offset of the rims. You did verify the offsets before buying, correct?
Old Mar 30, 2007 | 07:57 PM
_NIZMO_'s Avatar
_NIZMO_
Why do the stock wheels have diff sizes from front and back.
Old Mar 30, 2007 | 08:37 PM
Ebony350's Avatar
Ebony350
For handling. Drive wheels being in the rear, they need more rubber
Old Mar 30, 2007 | 08:51 PM
_NIZMO_'s Avatar
_NIZMO_
Exactly so shouldn't my new wheels have been smaller in the front?
Old Mar 30, 2007 | 08:57 PM
HDPDZO6's Avatar
HDPDZO6
Doesn't matter the wheel matter (for the most part). What matters is the rubber on the ground. Even though the front/rear wheels are same size, doesn't mean you have to have the same width tire on both. It depends on the use planned for the car as to what tire size.
Old Mar 30, 2007 | 09:41 PM
_NIZMO_'s Avatar
_NIZMO_
Ok last question is ok that the rings are plastic aka are they more likely to break
Old Mar 30, 2007 | 10:37 PM
terrasmak's Avatar
Plastic is just fine , when installed it will have equal force all the way around. There really no load bearing either.
Old Mar 30, 2007 | 11:30 PM
skmaxima2535's Avatar
skmaxima2535
its all good plastics fine
Old Mar 31, 2007 | 06:28 AM
_NIZMO_'s Avatar
_NIZMO_
I wish someone would answer my question though, why are the factory wheels made bigger in the back. I understand that tires make the difference, but still why are the factory rims diff sizes, why didn't they just do the method I am using(like many others on the forum) which is to have the same wheel size all around, but with diff size tires, thanks to anyone who can answer this question.
Old Mar 31, 2007 | 06:30 AM
Jay'Z's Avatar
Jay'Z
Old Mar 31, 2007 | 07:20 AM
WalkerT's Avatar
WalkerT
Professional
The plastic rings are centering rings. They go in the back side of your rim and keep it centered while you tighten the lug nuts. This will help them stay centered that is it. It is not a spacer.
The factory uses different size rims for the perfect fit for the different tires. If the factory uses different size tires/wheels it is to help reduce oversteer.
