Can you Rotate your Tires?
I just came from the dealership and they suggested I rotate my tires. Now I've seen postings on the board saying you cannot rotate the tires for the Z. Is that only for grand touring? I currently have the BASE 350Z. Thanks for anyones help!
You cannot do Front to Rear because your tires are most likely different widths, and then you would be running wider in the front than the back. And that would be retarded, unless you want ****ty launching and amazing understeer!!!!!
And you can't switch sides cause then the tires will rotate the oppostite direction that they are used to, and they will explode. Haha.
So the easy answer is no, not on Z.
Originally Posted by Wired 24/7
Yes here is the thread:
https://my350z.com/forum/showthread.php?t=137762
Chris
Totally off topic...
Anna went premium! BTW, are you going to HIN on 4/21?
Just thought I would fix the "tire blow up" wrong direction theory while I'm at it. Putting tires on with the wrong direction will NOT cause it to blow up. The only difference will be it will not perform the way it should, but it's not going to blow up when you drive on it.
as already said:
you CANNOT rotate front to back..
left to right rotations are fine
OFF TOPIC-
anna got free premium because of her photoshoot
4/21 is my b'day
Originally Posted by bb1314
+1
4/21 is my b'day
+1
Originally Posted by push
*BUZZZZZ* Just thought I would fix the "tire blow up" wrong direction theory while I'm at it.
I hadn't made plans cause I don't have anyone to go with, but I have been wanting to go. Are you? Hmm I need to find someone around here to go with.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
