Rim exchange
Old Apr 16, 2003 | 01:13 PM
Rock_DJ's Avatar
Rock_DJ
Default Rim exchange
My roomate has some handmade 3 piece rims from his NSX. The Lug patterns are exactly the same as the 350 Z. The rims should just slide on. The only problem is that on my Z on the drum of the wheel there is a lug nut which prevents the NSX rim from just sliding on. On the back of both the Z rim and NSX rim there are slots bored out for the lug to fit into but the lug on my Z is too big for the slot on the NSX rim. (hehehe...sorry being dirty). Now my question is this..or perhaps question(s). What is the lug nut there for? Can I remove it? Is it possible to perhaps find a lug nut that is smaller for my Z drum so that the NSX rim will finally fit? Would it be wise to bore out the NSX rim a little bit to make it fit? Would that interfere with the itegrity of the rim?
Any help would be appreciated
Thanx
Old Apr 16, 2003 | 01:29 PM
droideka's Avatar
droideka
You mean the gold post about an inch long? That "lug nut" is simply a device to keep you from mounting the rear tires on the front by accident. It comes right off.
Old Apr 16, 2003 | 02:02 PM
Rock_DJ's Avatar
Rock_DJ
So, It holds nothing on or togerther? It doesn't hold the drum together? I can just take it right off?
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
