Buying Rota Time Attacks - what tires?
Old Apr 17, 2007 | 08:18 PM
d!abolic's Avatar
d!abolic
Alright, so I think I'm gonna go with +20 offset and 35 AR. How about the width though? I like wide rears, so I was thinking 285. How about the fronts?
Old Apr 17, 2007 | 09:27 PM
ZSpectrum's Avatar
ZSpectrum
Originally Posted by 350Zenophile
ZSpectrum, pics please!
Will do, my cell phone takes ****y pics and Ive been sick Ill try for tomorrow, what kind of shots would you like?
Old Apr 17, 2007 | 09:31 PM
da-masterbater's Avatar
da-masterbater
Uniroyal Tiger Paws.
Old Apr 18, 2007 | 06:13 AM
350Zenophile's Avatar
350Zenophile
3/4 view shots showing the whole car, but close enough to see how the wheels/tires sit in the wheel well. Also, keep the front tires straight...no funky angles. Thanks!
Old Apr 18, 2007 | 07:49 AM
twenzel's Avatar
twenzel
265/35/18 and 2.5" drop... It will look nice
Old Apr 18, 2007 | 06:30 PM
jjaujou's Avatar
jjaujou
Hey, so how come some of you are matching rim sizes front & back instead of keeping them staggered?
Old Apr 18, 2007 | 06:39 PM
Scarab440's Avatar
Scarab440
Wider is better didn't you get the memo?
I run 18x9.5 +22 on all corners because it is the recommended rim width for my tire sizes 265 Front, 275 rear.
Old Apr 18, 2007 | 06:46 PM
TimeAttkZ's Avatar
TimeAttkZ
Ive researched this set-up for a while now ...
Rota p45 Flat black w/ red lip
+20 is the best offset in my opinion and then get some spacers for the rear for a real aggressive look. The plus about going with 18's are your tire selection. I would go with Falken Azenis rt-615 265 front / 275 rear. This will minimize under steer that you get with a 255/295 type set-up.
I almost sold my real Time Attacks to go with this set-up just because I wanted to use 18's and better tires while saving some money for FI. I love my Volks too much to let them go tho.
Its still tempting to make the switch tho ... I payed more than twice the amount of this set-up for my volks/yokos .. yes my set-up looks perfect and I have the real deal ... I hate knockoffs ... but to save 2 g's and use it for FI just for a small diff in looks (maybe a big compromise in quality).... ahhh makes it difficult to pass up.
Old Apr 20, 2007 | 01:50 PM
TimeAttkZ's Avatar
TimeAttkZ
So.... whats the final decision Im curious ???
Old Apr 20, 2007 | 08:52 PM
mistico's Avatar
mistico
Just curious...
What's the weight difference between the Volks and the Rota'sin this particular model?
The wheels look pretty good. Nice choice.
Old Apr 21, 2007 | 09:28 PM
TimeAttkZ's Avatar
TimeAttkZ
Well the Time Attacks are 19" 9.5 front 10.5 rear widths and the Rotas are 18" 9.5 all around .... so you cant really compare them in weight.
Old Apr 23, 2007 | 11:01 AM
dan avoN7's Avatar
dan avoN7
I havent seen a weight comparison between the TE37 and P45R.
I have seen the Volk RE30 weight compared to the Rota SVN (copy of the RE30) The Volk was around 17lbs in 18x9 and the Rota SVN was 20lbs in 18x9. Thats really close.
Old Apr 23, 2007 | 11:24 AM
bboypuertoroc's Avatar
bboypuertoroc
Since all the info you need is already in here, just gotta say one thing... those are not Time Attacks.
Old Apr 23, 2007 | 11:25 AM
bboypuertoroc
That's a big difference when it's unsprung rotational weight.
Old Apr 23, 2007 | 01:53 PM
ke0ki2k's Avatar
ke0ki2k
35 as in 35% of the overall width of the tire is sidewall. so a 275/35 will have a wider contact patch than a 275/45 since only 35% of the width is taken up by sidewall as opposed to 45%.
Old Apr 23, 2007 | 02:28 PM
350Zenophile
This is correct.
This is wrong. The width is a constant figure measured in millimeters.
Old Apr 23, 2007 | 04:16 PM
Nihilation's Avatar
Nihilation
If a tire says 275/35/18 then the width of the tire is 275mm across. The 35 means that 35% of 275mm is the total height of the sidewall. So:
275mm(width) x .35(sidewall) x 2(two sidewalls when measuring tire height) + 18in(wheel diameter) = 25.6 inches(total height of a the tire)
The factory tires are 26.7 inches tall in the rear and 25.7 inches tall in the front. A rear 275/35/18 is nearly a full inch shorter than the correct size of 275/40/18 and will add ~5% more milage to your car's odometer every time you take a drive. Food for thought.
Old Apr 23, 2007 | 05:24 PM
  #38
d!abolic's Avatar
d!abolic
Anyone wanna get this?
Workshop12
Mar 23, 2020 01:45 PM
davidm350
Oct 31, 2015 02:28 PM
kyin
Oct 15, 2015 05:54 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
Mw870
Sep 10, 2015 07:50 PM
