Help, my rear rim wont come off!
Old Apr 24, 2007 | 03:42 PM
acmw's Avatar
acmw
Default Help, my rear rim wont come off!
I jacked up the car, removed the lugs and tried to remove the tire/rim and the ***** wont come off, i even hit it with a hammer. Wtf can it be?
Old Apr 24, 2007 | 03:43 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
If the lugs are all off then the wheel should come off. Just give the tire a good kick. Unless of course you have some sort of spacer or hub ring that's stuck.
Old Apr 24, 2007 | 03:54 PM
blaukal's Avatar
blaukal
^+1 -- if you have aftermarket rims with hubcentric rings you may need to wiggle them back and forth to get them out...
Old Apr 24, 2007 | 03:59 PM
97ITR's Avatar
97ITR
I've had that happen to my old car before, lower the jack slowly and the wheel should pop off under the pressure. Alternatively, a swift kick would also do it but that might damage something.
Old Apr 24, 2007 | 04:02 PM
Sean's Avatar
Sean
take a hard corner, that should do it .
Old Apr 24, 2007 | 04:37 PM
acmw's Avatar
acmw
i tried everything, could it be that one of the studs are bent?
Old Apr 24, 2007 | 04:40 PM
Nihilation's Avatar
Nihilation
LOL, no, you're just not hitting it hard enough. Quit being a ***** and take that wheel off!!
Old Apr 24, 2007 | 04:49 PM
Eazzy's Avatar
Eazzy
Patience---Spray Liquid Wrench in the center hub area and let it set for awhile, then using a block of wood on the inner rim edge turn the tire and rap it with a good size hammer alternatlly. If it is real stubborn, you may have to take a butane torch and GENTLY heat the rim area around the center and try it again. (expansion and helping the penitrant penitrate ) After it is off, clean hell out of it and use a little anti-sieze compound in the lockup area so no probs in the future
"sumwhere" doesnt tell me where you live, so that dont tell me a fukcin thing, but rust and oxidation is the culprit
Old Apr 24, 2007 | 04:51 PM
acmw's Avatar
acmw
Im in nj.....btw- anyone know a good place in nj that fixes bent rims and curb rashes?
Old Apr 24, 2007 | 05:34 PM
Sean's Avatar
Sean
is the wheel off? is it bent bad?
Old Apr 24, 2007 | 06:54 PM
Thumbs up
Liquid Wrench is a winner!
Old Apr 24, 2007 | 06:56 PM
Bent wheel? How do you bend a wheel? Photos please.
Old Apr 24, 2007 | 07:15 PM
Eazzy's Avatar
Eazzy
Cool stuff, been around for a 100 years and cheap. I remember when WD came out, I was a kid, Big AD campaign.
The best stuff is never advertised, Doesnt need it
Old Apr 24, 2007 | 07:42 PM
acmw's Avatar
acmw
the 2 front rims are bent from pot holes, i want to remove the rear rims are replace them with the stocks until the others are fixed. i dont wanna be driving around with diffrent rims
Old Apr 25, 2007 | 07:28 AM
The wheels may be able to be fixed. Expensive. After repairing, there is no assurance that they can ever be properly balanced.
Old Apr 25, 2007 | 07:30 AM
Sean's Avatar
Sean
think he got them off the car yet? or did he fall asleep with a prybar in his hands
Old Apr 25, 2007 | 07:34 AM
VO...'s Avatar
VO...
Administrator
+1.
My rims are the same way. They are custom made to fit the Z only, with no hub adapters. What happens is the mating part of the wheel forms a thin layer of oxidation that bonds to the rotor's hub. Sit on the floor next to the wheel, use a heavy rubber mallet to beat the back of the rim. Keep turning the wheel so you beat it equally all around. You can put an old rag where you hit it, incase your self conscience about scuff marks on the back side of the rim. BTW, don't bang on the tire. Hit the lip of the rim. It takes a little while, but some old fashion elbow grease and cojones will get it off.
Old Apr 25, 2007 | 07:35 AM
VO...'s Avatar
VO...
Administrator
Personally, I thought the "take a hard corner" idea would have worked...
Old Apr 25, 2007 | 07:52 AM
supra crazy's Avatar
supra crazy
Well if you still have not taken the rims off you might wanna try lowering the car with the lugs off then rasing it and hitting it again with the hammer to see if it mad it a little easier. The same thing happend with my friends S4.
Old Apr 25, 2007 | 08:05 AM
JCat's Avatar
JCat
I have seen incorrect wheels installed on a vehicle where the hub was literally pressed into the center of the wheel. We took all the lug nuts off and did donutes in the parking lot. It was a brand-new Lincoln.
Ended up using a wheel puller.
