About to buy these rims...
Old Apr 24, 2007 | 07:22 PM
kdogg24's Avatar
kdogg24
Default About to buy these rims...
Hey guys, I am about to buy these rims with the following specs, and my question follows the specs:
Bolt pattern : 5x114.3mm
Size : 18x8.5 Front & 18x9.5 Rear (** Staggered Fitment**)
Offset : 20mm Front & 25mm Rear
I currently have stock 18" rims with the follow tires on the rims:
Front: 225/45/18
Rear: 245/45/18
With the new size rims, will I be able to fit the tires I currently own on the new rims, or will just the rear tires fit on the front?
Old Apr 24, 2007 | 07:28 PM
nooooorb's Avatar
nooooorb
I think this question has been answered before but...
NO & NO. The best fit for the wheels you're getting are 245/40-R18 fronts and 275/40-R18 rears. You can also go with 265/40-R18 rears but you have more brand options with the larger rears.
Old Apr 24, 2007 | 10:14 PM
terrasmak's Avatar
you can put your stock tires right on those wheels , no problems . But the above mentioned combo would be great to go to once the stockers wear out.
Old Apr 24, 2007 | 10:16 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
bad advice don't listen to this guy. You could maybe put the rears on the front (I wouldn't go that route) and get new rears but other than that you need to get new tires.
Hint: Before thinking about tires do some research and find out what the stock rolling diameters are. Then look at the tires that you want to buy and compare it's rolling diameter with stock and the rim width range given.
Old Apr 25, 2007 | 06:25 AM
I do not recommend a 245 mm tire on a 9.5 inch wheel.
Old Apr 25, 2007 | 07:09 AM
redlude97's Avatar
redlude97
don't people run 245's all the time on their 9.5/10.5 setups?
Old Apr 25, 2007 | 07:20 AM
MR_X's Avatar
MR_X
I'm running 245/35-19s on my 19x9.5 TEs no problem. You can fit your stock tires on there but what is the point to upgrade rims if you are not going to upgrade the tires?
Old Apr 25, 2007 | 07:48 AM
kdogg24's Avatar
kdogg24
I dont want to buy new tires because I just got new tires in December. I would like to get new rims, but not have to buy new tires along with them
Old Apr 25, 2007 | 08:54 AM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Here's a question... Could he use his stock 245/45/18 rears on the front of the new wheels and get 275/40's for the rear? I got the 245/40 on my Emotion 18's with 8.5 front, but I think the 40 series a little small compared to the 275/40 rear's I have. I understand that a 245/45 may mess up speedo calibration a little, but it shouldn't much.
Personally, I think that the 245/45 front and 275/40 rear's are a good idea, plus it will save him some money with only having to buy 2 tires instead of 4.
I say go for it with moving your stock rears to the new wheel fronts and just pick up a set of 275/40's for the rear of your new wheels. Check the classifieds you should be able to find some nice used or new tires there. If not, E-Bay.
Old Apr 25, 2007 | 08:57 AM
Fluid1's Avatar
Fluid1
Do you even know how much those rims weigh?
Old Apr 25, 2007 | 09:01 AM
MyV6IsFast3r
It's his 1st set of rims and he don't care about weight at the moment. That was the 1st question I asked him too lol.
Justin100
Nov 25, 2021 06:26 AM
Alexreyes
Sep 30, 2015 11:30 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
