Would this wheel setup fit a Z?
Old Apr 30, 2007 | 11:13 AM
hagausaf's Avatar
hagausaf
Default Would this wheel setup fit a Z?
Ok, I know many of you guys may think i'm stupid for asking this but I know jack crap about cars. Would 285/35/18 in back 245/35/18 in front fit directly onto a Z or would I need any spacers? Again bear in mind I know nothing about cars. Thank you in advance for your replies. Oh, reason I am asking is I have found some TSW Thruxtons for a great deal and was curious if they would fit my Z.
Old Apr 30, 2007 | 11:20 AM
nismo33's Avatar
nismo33
BoNe SToCK BaSe
It's the offset of the wheels and not the tire size that will determine if you need to rock a spacer. As far as the tire is concerned you should have no problems using those sizes.
Old Apr 30, 2007 | 11:24 AM
z32 fairlady's Avatar
z32 fairlady
It'll work. And Nismo^^ is right. I'm running 255/35/19 and 285/35/19 on the '04 car is not lowered, should not make a difference.
Old Apr 30, 2007 | 12:27 PM
scotts300's Avatar
scotts300
What are the offset and wheel width of the TSWs? The tires you are asking about are fine if put onto a wheel fitted for a 350z.
Old May 1, 2007 | 07:05 AM
i8acobra's Avatar
i8acobra
Tire size doesn't matter. What are the rim specs... width, offset?
Old May 1, 2007 | 07:21 AM
Takhteh's Avatar
Takhteh
I would go for 40 sidewall, NOT 35 if using 18s.. unles you plan to drop, which it doesn't sound like. But different tire sizing AND dependent on the wheels specs.
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
