Spacers for Volk SF Winnings
Old May 2, 2007 | 09:38 AM
2 low Z's Avatar
2 low Z
Default Spacers for Volk SF Winnings
I know I'm going to get flamed for this, but the truth is I'm just too damn lazy to take off a wheel and check. Will this type of spacers work on Volk SF Winnings? I'm would like to add a 10mm spacers to the rear and would prefer not the repace the studs.
Old May 2, 2007 | 09:50 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
I'd flame you for not even giving us the wheel size, offset, and suspension specifications (aftermarket? stock?)
Old May 2, 2007 | 10:07 AM
2 low Z's Avatar
2 low Z
Thanks man, I'm just asking if they'll bolt up. Not worried about clearence issues. But since you asked.
Volk SF Winning
Front 19/9.5 +17 BFG 245/35
Rear 19/10.5 +29 BFG 275/35
Lowered on Tanabe NF210
Fenders have been rolled fo the change in offset in the rear.
As far as other changes, a set of Stance coilovers are in the closet. Thanking about tire size change to 265/30 front and 295/30 rear.
Boost is in the works as well.
Old May 2, 2007 | 10:12 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
I think it will fit with the 275 but with the 295 it will be really tough. You might wanna wait and consult with the pros on this one. As for the offset a 10 mm spacer will set you at +19 which shouldn't be a problem. I see people running +18 rear all the time. I have seen 285s in the back but not 295s.
I would recommend only the one I used because I experience with it and that's H&R I really like their spacers due to the quality builds. Project Kics is also a good brand.
Old May 2, 2007 | 10:21 AM
2 low Z's Avatar
2 low Z
Thanks, I'll probably go with the H&R or Eibach, but I'm just trying to figure out if the wheels have indents on the to allow for the lugs that hold on the spacer to the studs. I can't remember.
I've never used these type of spacers before, I don't even know if it's required.
Old May 2, 2007 | 10:23 AM
2 low Z's Avatar
2 low Z
What happened to the pic??
Old May 2, 2007 | 10:59 AM
redlude97's Avatar
redlude97
I don't think the volks had the recesses in the mounting face to clear the 14mm of stud sticking out past the spacer, I think your only option is to use the type of spacer that replaces the stock studs.
Old May 2, 2007 | 01:07 PM
2 low Z's Avatar
2 low Z
Thanks, that's what I was looking for.
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
