2006-2007 Oem Offsets?
Old May 5, 2007 | 10:06 AM
Phantom Menace's Avatar
Phantom Menace
Exclamation 2006-2007 Oem Offsets?
Hi.
I've been searching all the live-long day and at my witts end. I hope you guys could be of some help?
I have the OEM wheels for my 2007 coupe with 20mm spacers up front and 25mm in the rear. I love the way the are flush and am wanting to upgrade my wheels.
My question now, is, does anyone know the offsets for the OEM wheels?
What I'm trying to do is, and please correct me if I'm wrong, is subtract my spacer size (20 & 25mm) from the OEM offsets so I could find the "ideal" offset in a wheel and not have to use spacers.
Nothings wrong with the spacers and I really don't mind using them, I'm also curious to know if a wheel I buy could use my existing spacers?
Thanks in advance.
Old May 6, 2007 | 03:29 PM
Gilley's Avatar
Gilley
They are 18x8 +30 front and 18x8.5 +33 rear.
Old May 6, 2007 | 08:25 PM
Phantom Menace
Thanks. I appreciate the info!
On more question: With 20mm front and 25mm rear spacers, would I get any rubbing issues if I kept the spacers and used 19X8.5" +25 (245/35/19) front and 19X10.5" +35 (275/35/19) rear rims?
Old May 8, 2007 | 05:18 PM
Auto RnD's Avatar
Auto RnD
In the front i would only do 15mm max and in the rear only 10-15mm.
ideally be around this:
8.5 +10 and
10.5 (+20 to +25)
Rishie
Old May 9, 2007 | 12:41 PM
Phantom Menace
8.5 +10 and
10.5 (+20 to +25)
Rishie
Thanks Rishie! By 10-15mm (rear), do you mean the offset of the wheel or spacer?
Old May 29, 2008 | 01:09 PM
Phantom Menace
I'm trying to refigure this...
Right now I have:
18x8 +30 front (with 20mm spacer) and 18x8.5 +33 (with 25mm spacer) rear.
So, if I'm looking to get the EXACT offsets I should uset the offset calculator to match:
Fronts: 8" +10
Rear: 8.5" +8
Thanks!
350z82
Oct 1, 2015 06:25 PM
