Tell me if I need Spacers to get the look
Old May 8, 2007 | 01:42 PM
slow down's Avatar
slow down
Default Tell me if I need Spacers to get the look
You know the look I'm talking about. Flush. Tires right in line with the top of the fender. Here's what I have - tell me if I need spacers, please! And WHAT SIZE?
245/35/19x8.5 (front) - w/ 20mm offset
275/35/19x9.5 (rear) - w/ 35mm offset
Eibach Sportline Springs (1.2" f / 1.2" r)
Do I need spacers to get the right look? What SIZE?
Thanks!
Edited: Thanks davidv!
Old May 8, 2007 | 01:45 PM
Question
You left out a minor detail. The size of the wheels?
Old May 8, 2007 | 03:19 PM
redlude97's Avatar
redlude97
9.5+35 is going to be really sunken, spacers are definately needed
Old May 8, 2007 | 03:27 PM
___DJK___'s Avatar
___DJK___
+20mm or +25mm spacer!
Old May 8, 2007 | 06:24 PM
Alberto's Avatar
Alberto
Cranky FI Owner
10-15mm in the rear will be fine.
Old May 8, 2007 | 07:59 PM
Volk350Z's Avatar
Volk350Z
Master
10mm front & 20mm rear would be nice..
Old May 8, 2007 | 09:10 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
10 in the front and your going to have to do fender work. The front should be fine. Stick a 15mm on the rear and it should be perfect.
Old May 8, 2007 | 09:22 PM
redlude97's Avatar
redlude97
No way a 10mm spacer is going to cause the wheels to rub the fender, remember this is only an 8.5" wheel. An 8.5+10 has the same out lip position as a 9.5+23. I say a 15-20mm spacer on the front would work fine. For the rear, if you are willing to roll your fenders, then a 30mm spacer will work with plenty of clearance. I'm running a rear 9.5+30 with a 25mm spacer and a 285/35/19 tire with my fenders rolled, and I clear fine. Planning on 20mm spacers for the front wheels next
Old May 9, 2007 | 04:13 AM
slow down's Avatar
slow down
I think I goofed fellas.
The rear is a deep dish, front is not.
So I think the front is 19x8.5 +35 / rear is 19.9.5 +20
Sorry for the confusion. I believe I had it backwards.
Old May 9, 2007 | 05:07 AM
davidf's Avatar
davidf
Pics. will help.
Old May 9, 2007 | 06:43 AM
slow down's Avatar
slow down
I don't have any pics yet. In fact, if I had pics that would mean the wheels were on the car and it'd be easy for me to tell what size spacers I need. BUT, my patience is lacking and I wanted to see if I could pre-order the spacers and put everything on at once. I know it's a long-shot, but I thought some of you guys would have some insight on what spacers I need based on your experiences with your own cars and reading this forum for a year or more.
So, ignore the post if you wish, but if you have a firm idea on offsets for an '03 350z, I'd like to hear your thoughts.
Once again, what I'll be working with...
Front - 245/35/19x8.5 +35
Rear - 275/35/19x9.5 +20
Eibach Sportline Springs (1.2" drop all-round)
Thanks
Old May 9, 2007 | 07:58 AM
kbomb's Avatar
kbomb
just get 15mm or 20mm spacer for the front and you should be good.
Old May 9, 2007 | 08:18 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
1.2" drop? Your rear camber will be doo-doo if you don't get a rear camber/toe kit installed.
Old May 9, 2007 | 05:33 PM
big jon's Avatar
big jon
the frts will be fine thats the set up i have and theyre pretty good, the neg. camber is gonna give the illusion theyre sunk in though. the rear... who the hell sold you a rim for a z with a 35 mm offset? thats sick. your gonna need a 15 0r 20mm spacer. see i have a 20mm offset wheel and its close to rubbing just a hair if it was lower. ( its only lowered .7in) better buy some stock in a tire co. if you dont plan on a camber kit! good luck
Old May 9, 2007 | 08:26 PM
dutchboy350Z
Finally some go
+1
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
