Wheel Spacer Recomendation
Well since we are on the topic, does anyone care to give advice about spacer size to me?
Front: 19x8.5 with a +29 offset
Rear: 19x9.5 with a +35 offset (TE37s)
Car is lowered with RS*R springs (.6 inches)
I was thinking 5 mm spacer up front and 10 mm spacer in the rear - that would be just slightly LESS aggresive than the folks with 19" Volks with a +22 setup all around.
What do you think? My hesitation about going bigger is additinal stress on the bearings and even more weight being added to the car.
Thanks,
Kev
Thanks,
Kev
Thanks,
Kev
Thanks,
Kev
Thanks help would be much appreciated.
Originally Posted by LouiZ
I have the same issue as you except i have +30 in front. I've been doing my research and most gets 20mm front and 25mm rear but that's the oem stocks offset. My front offset, i believe to be the same as 06+ wheels offset. but my rear is +35 and thats a problem and i cannot figure what mm spacers to get that.
I'm still looking into this, but a member on a different site indicated that he has a +35 wheel in the rear and the 15 mm spacer works great.
The fronts are still an issue. You have +30, I have about the same, +29. I wanted to go with a 10 mm spacer. That size is made by Ichiba, but rumor has it that it is a real pain. Apparently its exactly the same size as the existing hub, preventing you from centering your wheel with the original hub. Plus, its apparently too thin to add a hub centric ring???? I need to investigate further, but if someone out there as been able to put a 10 mm spacer on the front, PLEASE let us know.
Peace.
Originally Posted by tommyjeans214
hey
for those who got spacers, did you need the hubcentric ring?
if so, what are they for?
thx
thx
It is not recommended to use universal spacers without the hubcentrc ring because you probably won't get them perfectly centered and you may experience some vibration.
Recently, I bot these 25mm Ichiba's and installed them front and rear. EBAY SITE
I never expected to receive any comments about the "new look" but I have received many.
Pics of your ride w/ Spacers?
Peace.
Peace.
To update this: Apparently the 10 mm spacer from Ichiba DOES have a ring machined in. Its the Eibach 10 mm spacer that doesn't and therefore may be a pain.
LIke this guy Link. https://my350z.com/forum/media-share/273542-pics-front-lip-wheel-spacers-56kbeware.html
^^^ btw nice car =D
would a 10mm spacer make the rear nicely flushed?
Originally Posted by z-u-later
Here is a picture of my Z (cloudy day) with spacers on track rims & Toyo RA-1 race tires (track setup):
I'm thinking of getting some spacers for mine and trying to decide which widths to go with.
Thx!
