Lugnut lock broke off and need some help!
Old May 19, 2007 | 04:51 PM
scottone928's Avatar
scottone928
Default Lugnut lock broke off and need some help!
I bought some new rims, and when I was tightning up one lugnut locks it broke. It sheered 1/3 of the top off, and when I look into the lug lock itself, it has a missing piece. My question is, what is the best way to try and get it off without scratching up my new rims. These are the factory lugnut locks. Any advise would be great. Thanks..
Old May 19, 2007 | 05:03 PM
locknut's Avatar
locknut
Default somewhat of a safe removal
well i had a problem where i had lost my lock nut and had read many forums suggesting to try and crack the locknut...wasnt going to even try that...however with real realative ease i did this...i hammered on a tight fiting imperial socket right over the whole thing then gently with an impact gun just slowly reversed it off... worked like a charm i did however only get two rims off with one socket then had to buy another socket and got the other two off...hope this helps
Old May 19, 2007 | 05:29 PM
DavesZ#3's Avatar
DavesZ#3
I had the same problem and used locknut's solution. Hammer a 3/4" (IIRC) socket on the lock and take it off with an impact wrench.
If it won't come loose, try this trick... tighten the two nuts adjacent to the stuck lock and loosen the remaining two. That will take some of the pressure off the lock and it will come loose easier.
Old May 19, 2007 | 05:42 PM
locknut's Avatar
locknut
Default just checked the garage...
so it was a 19mm 16 point socket that i used....which is metric sorry...
Old May 19, 2007 | 05:45 PM
scottone928
Those are great ideas. I will try those in the morning. Just pissed me off when it sheered. Thank you.
Old May 21, 2007 | 07:57 PM
f00man88's Avatar
f00man88
They make a kit, that has swirled edges in it. Its a regular half in. drive. identical to an impact socket only with edges in it to dig into the lock to spin it off. Hammer a 6 or 12 pt socket on there. make sure you get it on as far as it will go. gently spin it off. being in the tire buisness i do this a cupple times a week.
Old May 21, 2007 | 08:01 PM
f00man88's Avatar
f00man88
On a side note BE CARFULL your first attempt. a buddy of mine hammered on a 21 mill impact socket and it split in half shot up and cut his chin open, nice little trip to the emergency room. And to make your life easier trust me when i say this. the more times you spin the socket on the wheel lock the harder is is to get off. If it starts to spin, stop and hammer harder on it.
ablaine
Nov 29, 2016 10:13 AM
Mattg350z
Oct 2, 2015 06:51 AM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
