What tire combo for these rims?
Old May 20, 2007 | 07:07 AM
G35JCC's Avatar
G35JCC
Default What tire combo for these rims?
I'm looking at going with the Volk Progressiv Spoke 19" 9.5" +22F, 10.5" +22R to fit on my '07 G35 Coupe.
I am going to cut or roll the fenders regardless if I need to.
I have a few questions:
1. What tire sizes will match OEM look as far as rim to sidewall?
2. Will I need a camber kit?
I have seached the threads and have seen that this wheel size is very common and it pretty much says to run a 255F and a 285R. Sound like a good setup?
Thanks.
Old May 20, 2007 | 07:27 AM
DavesZ#3's Avatar
DavesZ#3
Yeap, go with the 255/35 and 285/35 combo. The diameters are close enough to OEM so that VDC will stay happy, speedo/odometer will be very close.
1) They will look better than OEM as far as wheel/tire scale.
2) No camber adjustment necessary.
Oops, just realized you're talking about a G35. What are your OEM tire sizes?
Old May 20, 2007 | 07:33 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
255/285 should be good to go.
Old May 20, 2007 | 07:36 AM
JDMFairlady21's Avatar
JDMFairlady21
you can also opt to go REAL wide with a 265/30/19 and 295/30/19 ... looks great on those rims... adam@z1 has the same sizes and i plan to go the same way as well.
Old May 20, 2007 | 07:56 AM
G35JCC's Avatar
G35JCC
OEM is 225/40/19 F 245/40/19 R.
Old May 20, 2007 | 01:14 PM
DavesZ#3's Avatar
DavesZ#3
Shouldn't those be //18" ? If so, they're the same as the Z so the 255/35 and 285/35 should be fine.
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
