Here are a couple pictures of my tires. Do I have the feathering problem?
Old May 22, 2007 | 02:29 PM
fr0ng's Avatar
fr0ng
Default Here are a couple pictures of my tires. Do I have the feathering problem?
It seems like one side of the tire has less tread than the other...does that mean I have the tire feathering problem? There are pics of my left and right rears..
Old May 22, 2007 | 02:30 PM
fr0ng's Avatar
fr0ng
Yes, I know I need new tires...
Old May 22, 2007 | 02:42 PM
redlude97's Avatar
redlude97
feathering is an issue on the front tires, no the rears, and those seem relatively even to me
Old May 22, 2007 | 03:03 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
+1 and yes you really do need new tires.
Old May 22, 2007 | 03:22 PM
A picture is worth a thousand words.
Feathering is symptomatic of the front tires. The rear tires do not turn. I see a minor difference in the wear pattern. Its insignificant. I would not even mess with a rear alignment.
Old May 22, 2007 | 03:43 PM
trains1937's Avatar
trains1937
+1. Those tires look really bald. Replace asap!
Old May 22, 2007 | 04:39 PM
DavesZ#3's Avatar
DavesZ#3
They're not down to the wear bars so technically they're still good. Would I drive them in the rain - NFW. Do they have as much grip as new tires, no.
Old May 22, 2007 | 04:45 PM
fithamoto's Avatar
fithamoto
Sleeps in 350Z
Tire feathering should produce uneven wear on the inside of your fronts. Alternating treadwear up and down. This also produces a "roaring" noise as you slow down to a stop. If you have this then you have to get the front end Camber adjusted and aligned. Most likely replace the front tires as well. Take it to Nissan and see if they will replace for free. They did on mine.
Old May 22, 2007 | 04:51 PM
gripfordough's Avatar
gripfordough
i would do one huge donut in a cul-de-sac somewhere and then replace with new tires.
Old May 22, 2007 | 05:12 PM
fr0ng's Avatar
fr0ng
ill do a fat burnout before i replace em...
Old May 22, 2007 | 05:13 PM
JDMFairladyZ33
Are you trying to kill him with that advice
Uriyo_
Sep 8, 2021 08:46 AM
