Will mixing these tires BAD ?BFGoodRich (F),Toyo (R)
Old May 24, 2007 | 04:55 PM
cutiewolf's Avatar
cutiewolf
Default Will mixing these tires BAD ?BFGoodRich (F),Toyo (R)
hey guys .. i have BF Goodrich g-Force T/A KDW NT all around ..i need to replace my rear tires cause passenger side rear is leaking air and it cant not be repair it has to be replace. the question is ..can i put Toyo PROXES T1-R in the rear? and leave the front with BF Goodrich? cause i like how the Toyo looks better..wat will happen to my ride if i change it to toyos?? will my car perform different? thanks yall!!
ps : tires size in rear are 285/35/19 if needed.
if anyone have a used BF good rich g-force T/A KDW II 285/35/19 please pm me!!
Old May 24, 2007 | 06:56 PM
Yes you can put different tires on the rear. Handling is uncertain. Tires are tested in groups of 4.
Old May 24, 2007 | 07:01 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
You can do this but you'll notice some performance differences between the two tires. With the Toyos you'll see less dry traction as well as lateral handling loss due to the softer sidewalls compared to the BFGs.
Old May 24, 2007 | 08:24 PM
The Brickyard Rat's Avatar
The Brickyard Rat
Can you do it? I suppose.
Should you do it? No, your compromising handlng.
And picking a tire because you like the way it looks is iodiotic, imo.
Old May 24, 2007 | 08:58 PM
turismo's Avatar
turismo
Yes you can, but I wouldnt do it.
Old May 24, 2007 | 09:01 PM
johnoppa's Avatar
johnoppa
you'll probably get oversteering a bit. it'll be okay unless you go hard into corners.
Old May 25, 2007 | 08:49 AM
cutiewolf's Avatar
cutiewolf
ic...alright i guess ill just stick with the BF-GoodRich then....thanks guys for helping me out!
ohh!! one more thing...should i replace both of my rears or just the leaking one?
Old May 25, 2007 | 08:52 AM
iStan's Avatar
iStan
ZR
I would personally replace both.
ablaine
Nov 29, 2016 10:13 AM
350z82
Oct 1, 2015 06:25 PM
