My car is shuddering.
Old May 29, 2007 | 10:27 AM
Nucleus's Avatar
Nucleus
Default My car is shuddering.
My 2005 Z with 44,000 miles developed this bad shuddering for no apparent reason. I noticed it friday nite. I didnt hit any bumps either. I cant take it to the shop until Friday.
I checked the tire pressures and they seem fine. when I drive slow it feels like one of the tires is "egg shaped". But all the tires and tread look okay. All the lug nuts are tight and I havent removed or replaced any tires for months.
when driving above 40mph everything vibrates. The engine sounds fine. I dont think it has anything to do with the engine. Allthough I took my knn intake off and reinstalled my stock intake friday. I disconnected the neg terminal and hit the brakes to reset the ecu.
anyone know what I can check?
Old May 29, 2007 | 10:29 AM
Fluid1's Avatar
Fluid1
MY care is intact. .
Old May 29, 2007 | 10:33 AM
Nucleus's Avatar
Nucleus
thanks
Old May 29, 2007 | 10:35 AM
Fluid1's Avatar
Fluid1
Ninja!
Okay. Sounds like it could be any number of things.
Warped rotor (unlikely)
Alignment is out of whack (could be)
Uneven tire wear (unlikely unless you flatspotted)
Definitely not the intake.
I would rotate your tires and see what happens. Check tire pressures again. Hit us back
Old May 29, 2007 | 10:42 AM
nzpv03's Avatar
nzpv03
hey I had a horrible shimmy while breaking but it turned out to be my tire pressure! re check =)
Old May 29, 2007 | 10:48 AM
Delusive's Avatar
Delusive
check your wheel lug nuts
Old May 29, 2007 | 10:57 AM
Nucleus's Avatar
Nucleus
I have the tire pressure sensors and they all say 38 psi. I will check again with a real tire guage when I get home. Thanks for the advice.
Hopefully this wont be expensive!
Old May 29, 2007 | 10:58 AM
h8bumps's Avatar
h8bumps
Does the steering wheel move, or do you feel the vibration in your seat?
I would guess maybe wheel imbalance. There's a chance one of your wheel weights fell off.
At what speed do you first feel it?
Old May 29, 2007 | 11:01 AM
Nucleus's Avatar
Nucleus
20 or 30 mph. I wasnt sure at first if it was my imagination but quickly realized my car was shuddering. I notice the passenger seat wont sit still, the wheel and the mirrors are vibrating like crazy, and my auto shifter vibrates like crazy. and if i was talking to myself my voice would sound like if you talk into a fan.
Old May 29, 2007 | 12:20 PM
MyZFiona's Avatar
MyZFiona
your wheels need to be rebalanced... sometimes when the dealer put on you wheel weights.. in this case with our stock rims.. they dont clean the area where the weights are applied.. this has also happen to me.. so check to see if you wheel are missing weights.. if so.. thats your prob..
Old May 29, 2007 | 01:10 PM
SSZVirginia's Avatar
SSZVirginia
That's my guess too.
Old May 29, 2007 | 02:05 PM
DavesZ#3's Avatar
DavesZ#3
If you feel that one of the tires is egg shaped at low speeds, then it probably is - hence the shudder at highway speeds.
While you might not see an "egg" shaped bump, the tire is probably out-of-round. This can happen when the belts and layers separate inside the tire. If you jack up the car and slowly rotate a wheel with your hand while watching the surface from the side, you should see it rise and fall.
BTW - it's not missing weights if you feel it at low speeds. Missing weights at high speeds cause a high frequency vibration, not a shudder in the whole car.
Old May 29, 2007 | 02:29 PM
Nucleus's Avatar
Nucleus
I left the car at work and took home a work vehicle but will check out these two leads tommorrow. The wheel wieghts and jacking the car to rotate each wheel individually. Thanks guys for the suggestions and thanks alot for not me.
Maybe this will give me an excuse to get some Toyo Proxies.
Old May 31, 2007 | 09:43 PM
Nucleus's Avatar
Nucleus
Okay I figured out my problem today. I noticed my right rear potenza has a huge bubble on the inner side. The bubble is appx 8 inches long. Damn faulty tires.
I will bring it to Nissan and see if they uphold the tire hazard warrenty I bought or if they try to slither their way out of it.
i will post a pic maybe tommorrow.
Old Jun 1, 2007 | 03:10 AM
xdragus's Avatar
xdragus
wtf 8" long...what can cause a bubble like that? ; / driver fault or just...bad terrors?
just asking questions since i'm noob ; / not saying you are bad driver unless you are...haha.
Old Jun 1, 2007 | 06:21 AM
Nucleus's Avatar
Nucleus
And it was a rear tire. I didnt hit anything. Heres a pic.
Old Jun 1, 2007 | 07:28 AM
That tire should have been replaced 5,000 miles ago.
Old Jun 1, 2007 | 07:34 AM
Nucleus's Avatar
Nucleus
This tire may look worn in the picture but is less than 1 year old and only has 10k miles on it. The tread is not worn.
Anyway I just dropped it off at the shop. Im waiting for them to call me.
Old Jun 1, 2007 | 01:45 PM
Nucleus's Avatar
Nucleus
Dealership replaced it free under my road hazard protection. Would have cost $377.00.
Old Jun 1, 2007 | 02:33 PM
Russ@Z1's Avatar
Russ@Z1
nice
