18x10.5 +22 Front and Rear?
Old Jun 2, 2007 | 10:23 AM
Racelex's Avatar
Racelex
Default 18x10.5 +22 Front and Rear?
Will the fronts work? I know the rears will...
Looking to put on 265 or 275 tires front and rear...
Thanks~
Old Jun 2, 2007 | 10:25 AM
r_seng's Avatar
r_seng
i believe the front will require neg camber (-2.9?) for that set up to work.
someone will correct me if im wrong.
Old Jun 2, 2007 | 11:15 AM
ppw350Zunit's Avatar
ppw350Zunit
my set-up is not quite as wide as "drumma" here:
https://my350z.com/forum/showthread....ght=work+vs-xx
but i have 18x10 +19 265/35/18 all around and no rubbing so far.
Old Jun 2, 2007 | 11:23 AM
OffsetZ33's Avatar
OffsetZ33
Ive put my rear 18x10.5 +22 on my front when the car was in the air and it cleared fine - close but it cleared. I did not put the car on the ground, but it should be OK depending on tire choice and ride height.
Old Jun 2, 2007 | 12:03 PM
ke0ki2k's Avatar
ke0ki2k
go 265/35 and it should fit. i have 265/40's on my 9.5's up front, i wouldnt push it any farther. 275's are out of the question for me, i like to go through the dragon and the suspension compresses big time so 275's will definately rub in the corners.
Old Jun 2, 2007 | 02:13 PM
OffsetZ33's Avatar
OffsetZ33
Make sure and try and stay with a 35 series profile (or even a 30 if you are really worried about it and are running wide front tires).
Old Jun 2, 2007 | 04:53 PM
SteveA's Avatar
SteveA
I found the biggest combo that worked on the front was 18x9.5's with a 30mm offset. This allows 275 tires. I use 275/35s, but 275/40s would also work. Clearances are tight on the inside, but still clear. I don't think you will fit much bigger on the ront without fender issues. Of course the same setup works fine on the back.
Old Jun 2, 2007 | 08:46 PM
OffsetZ33's Avatar
OffsetZ33
^^^ Like I said, my 18x10.5 +22 w/275/40 clears the arm also (very tight fit but barely clears), I am just not sure about fender clearance depending on how low you are, etc...
Old Jun 3, 2007 | 01:13 PM
LG_z33's Avatar
LG_z33
18x10.5 +22 with 265/35/18 tires will fit fine on the front
Old Jun 3, 2007 | 02:07 PM
JETPILOT's Avatar
JETPILOT
10.5" wheel with a 265 tire? That will look retarted. With a +22 offset up front you will rub if your car is lowered.
JET
Old Jun 3, 2007 | 06:46 PM
Racelex's Avatar
Racelex
18x10.5 +22 will clear inner supension??
As for as outside i will run approx 2 degrees of camber so that'll give me some extra room on the outside...
Thankyou
Old Jun 4, 2007 | 11:47 AM
OffsetZ33's Avatar
OffsetZ33
Yes
Old Jun 4, 2007 | 12:21 PM
97supratt's Avatar
97supratt
Nitto NT-01's very very nice choice. How do you like them? How is the tread wear on those things?
NA&CH's Avatar
NA&CH
I tried to fit my rgs with , I believe +22 rear with a 285 and the rim hit the arm... I was upset, I wanted to run 18x10 all around...
Not: atleast I think it hit the arm I had to marks like the arm...
Chris
Old Jun 4, 2007 | 02:27 PM
ppw350Zunit
Chris
you can still run 18x10 all around....just need 265/35 or 255/35 up front.
Old Jun 4, 2007 | 02:41 PM
Racelex's Avatar
Racelex
Thankyou everyone for your help...
Old Jun 4, 2007 | 02:49 PM
Andy@Performance's Avatar
Andy@Performance
Performance Nissan
My friend Steve Mitchell of M-WORKZ. Front; 18x10.5 +22, 295/35/18 with -3 degree camber with fenders rolled. Rear; 18x10.5 +22, 315/35/18 with -2 degree camber with fenders rolled.
Old Jun 4, 2007 | 03:08 PM
350z4steve's Avatar
350z4steve
Where is M-WORKZ located and do you know which camber bars he is using in the rear?
Old Jun 4, 2007 | 03:21 PM
Andy@Performance
Performance Nissan
M-WORKZ is a chassis tuning shop based out of Gardena, CA. Not sure which arms he has though.
Old Jun 4, 2007 | 05:48 PM
ppw350Zunit
wow, that m-workz z is sick!!!
