Can someone take a look at these lug nuts and tell me if it will work?
Old Jun 3, 2007 | 08:55 AM
SuperBlack350z's Avatar
SuperBlack350z
Default Can someone take a look at these lug nuts and tell me if it will work?
I was using some airtools at work and being a dumb*ss, i tried to rush myself at the very end and just used the air gun for my lugs without screwing them on first with my hand. I thought i stripped my studs so i bought new studs at nissan then finding out all i stripped was the stock lugs. I need another set of lugs and founds these on ebay. It has good reviews on this site as well. It says OE lugs and are shorter and fatter than the tuner lugs. Does anyone know if these with fit on stock rims with no problems whatsoever?
http://cgi.ebay.com/ebaymotors/Mutek...24673899QQrdZ1
thanks.
Old Jun 3, 2007 | 09:03 AM
SuperBlack350z
if i remember correctly, our lugs are lug centric so i don't see why it woudln't work, just wanted to make sure.
Old Jun 3, 2007 | 10:17 AM
ctwentytwo's Avatar
ctwentytwo
Those lugs will work, just make sure you got the correct pitch.
Though I am selling Trust (Greddy's parent company) Lugs here:
https://my350z.com/forum/pacific/275122-fs-trust-short-closed-lug-nuts.html
Super light weight. $55 shipped to mainland. PM me for details.
Old Jun 3, 2007 | 10:24 AM
SuperBlack350z
i think the ones you are selling are for aftermarket rims. I need something for my stock rims.
Old Jun 3, 2007 | 11:26 AM
JETPILOT's Avatar
JETPILOT
Stock and aftermarket.... same thing. Those lugs are hot and a great price. But I need extended!
JET
Old Jun 3, 2007 | 11:28 AM
SuperBlack350z
so what you are saying is that on the 350z, you can use tuner lugs?
Old Jun 3, 2007 | 12:39 PM
ctwentytwo's Avatar
ctwentytwo
Yeah... here's pics of a stock lug on the left, cheap tuner lugs in the center, and the Trust lugs on the right. The taper angle on all of them are the same... 60 degrees.
Notice that the seat (where the lug contacts the wheel) is all the same size, although the stock lug takes a 21 mm socket; while the Trust lug takes a 19mm, making the body thinner so you can use a thinner socket. Why a thinner socket? Because usually, aftermarket wheels have smaller diameter hole to fit the socket in.
In summary, yeah, you can use "tuner" lugs on a stock wheel.
Old Jun 3, 2007 | 12:43 PM
SuperBlack350z
^^ thank you so much, that was very imformative.
Old Jun 4, 2007 | 01:19 PM
dkorr's Avatar
dkorr
I would looks for lugs with the following features:
non-open end (exposed thread)
washer at the seat
spline drive format
<20mm dia key
all these features helps keep ur wheels scratch-free
_bit
Oct 2, 2015 07:49 AM
